Rokblokz Mudflaps
GeeBee
Gus
Aberdeen, Scotland
JLU Rubicon 2.0 GME
Engineering Manager
Hi has anyone else installed a full set of the quick release mudflaps from Rokblokz?
I ordered a set recently and after a bit of fettling (Euro Fenders have a different outside lip profile to USA evidently) eventually managed to install the front pair last night. I ran out of time to fit the back pair, but spent a few minutes looking at how the rear bracket mounts to the chassis. It looks like once it's installed, you can no longer re-fit the splash guard that sits in front of the rear bumper without some heavy modification and the Rokblokz installation sheet makes no mention of this.
Does anyone have any tips they can share? Thanks.
GeeBee
GeeBee
Gus
Aberdeen, Scotland
JLU Rubicon 2.0 GME
Engineering Manager
Sorry. Just realised I posted this thread in the wrong section, should be in exterior mods. How'd I get it moved?
:facepalm:
melendez69
Marc
Pineville NC
2018 3.6 JLR / 2013 911 / 2013 E92 M3
Backup for The Stig
A few of us have...here's my initial setup...
https://www.jlwranglerforums.com/fo...-your-jeep-jl-today.3033/page-928#post-620000
...and then with a slight modification on a tip from a couple of members starting at #14481
https://www.jlwranglerforums.com/forum/threads/what-did-you-do-to-your-jeep-jl-today.3033/page-966
Can you show a picture of the limitation you've run into?
Vulpine
Marco
Herts
Jeep Wrangler Rubicon 2019
:facepalm:
Hi dude, did you get these installed in the end? These are the best looking flaps around, but don't want to shell out that amount of $£ unless they work well? Cheers, oh and any pics would be welcomed! :)
greenvillebigwheels
Upstate SC
2019 Wrangler Unlimited Sport
Engineer
Just a heads up for others, the rears dont fit on the stock sport bumper. The bumper has plastic flares on it that stick into the wheel well way too far to install. I have an email into rokblokz to see if they have a solution but right now it seems like they only checked the rubicon bumpers for fitment.
ChimpanZed
Aaron
2020 Unlimited Rubicon
I haven’t been able to make the rears Rokblokz work with the fender liners on my Rubicon. After butchering the originals I bought a new pair to retry.
I duplicated the liner modification shown above and it doesn’t work. I have Rubicon steel bumpers if that makes a difference. In fact, I removed the brackets that hold the fender liner in place because they interfere with the mud flap brackets and impede anything but a near vertical orientation.
greenvillebigwheels
Upstate SC
Engineer
Yeah feel like it would be impossible to figure out exacly where to notch the liners on the first cut. I’m not sure if you were thinking I meant the liners but the bumper itself interferes on the sport badly even with the Liners removed.
Vulpine
Marco
Herts
I managed to get them and fit them to my Uk spec JL Rubicon. Took a few hours and a little hacking here and there on the flaps. I am very happy with them. https://revkit.com/kitsune
FrostQ
Canada
Rubicon
I successfully fitted the non-cut version (original size) of the RokBlokz to my Rubicon with Mopar Performance Rock Rails. The top 2 screws are installed as per instructions, and I put a nylon locknut behind to make sure it doesn't vibrate off. For the inner-side mounting point, I installed the metal clip and then zip-tied it to the mudguard. It is held tightly in place. The only difference is that the angle is not as tilted back as originally designed...I don't think it looks out of place. At least I didn't have to hack it.
mjmostek
Milwaukee
18 JL Sport S
Did you figure out how to install the rears with the stock Sport bumper?
OutlawBeard
Kansas City, MO
2021 JLUR Gecko Ordered 5/4/21 Delivered 8/27/21
I ended up doing the same to my front rokblokz, I put the Recon steps on my JLUR and the fronts just wouldn't fit, I ended up installing the top 2 bolts as they should and then the bottom I just zip tied them, my final install I'll be using some nylon spacers that are about .75"-1" but I need to get some longer M6 bolts first, the stock 1" are just barely too short. I really didn't want to cut the flaps.
Dwayne Lane's Chrysler Jeep Dodge
