acenines3
For Sale Rockville Car-Eq-Oke and Rockville Mic. Both are brand new and still in the box. Microphone come's with a hard case. $70.00 shipped CONUS.
The Rockville CAR-EQ-OKE is a multi-functional product that will change the way you listen to music in your car.
This is a high quality 7 band equalizer that allows you to fine tune your music. We also added Bluetooth so that you can play music from your smartphone or MP3 player in case your vehicles stereo does not already have Bluetooth.
What makes this product really unique is we added a microphone input with echo controls. You can take any wired microphone and plug it into the ¼” mic input and start singing along to your favorite tunes. If you go to car shows this is a great way to stand out from the crowd and have a party by your car. This is also cool if you are hanging out with a bunch of friends and you want to tailgate and do some karaoke or Caraoke.
Features:
1. Master volume
2. Sub volume
3. Fader
4. Input selector switch
5. 50 Hz control (+ or = 12 dB)
6. 125 Hz control (+ or = 12 dB)
7. 315 Hz control (+ or = 12 dB)
8. 750 Hz control (+ or = 12 dB)
9. 2.2 KHz control (+ or = 12 dB)
10. 6 KHz control (+ or = 12 dB)
11. 12 KHz control (+ or = 12 dB)
12. Microphone volume control
13. Microphone echo control
Features:
- Rockville CAR-EQ-OKE 1/2 Din 7 Band Car Audio Equalizer EQ w/ Microphone Input, Echo and Bluetooth
- Bluetooth audio streaming from any smartphone or other Bluetooth-enabled device
- High quality Bluetooth transmission with long range and no distortion
- ¼” microphone input allows you to talk or sing through your car stereo
- Mic volume control
- Echo effect knob is perfect for karaoke
- 7 adjustable bands of equalization (50Hz, 125Hz, 315Hz, 750Hz, 2.2KHz, 6KHz and 12KHz)
- Each band is adjustable from -12dB to +12dB
- Built in crossover
- Subwoofer level controls
- Built in 7-volt line driver
- Blue LED lights on each rotary knob
- Front, rear, and sub pre-amp outputs
- Aux input with gain knob to adjust aux volume
- Strong metal chassis with high quality rotary knobs for all controls
- Includes mounting brackets and screws for easy installation
- Amazing quality with low distortion (Built with top quality components)
- Frequency response: 20Hz TO 20KHz +/- 1dB
- S/N Ratio: 95 dB
- Crossover Roll-Off: 12dB per octave
- Input impedance: 10K
- Input sensitivity: 200mv per channel >7V
- THD: 0.01%
- Input: 12V
- Output: 12V
- Power requirement: 11-16V DC
- Unit dimensions in inches: 7.08” x 5.51” 1.26”
1. Master volume
2. Sub volume
3. Fader
