RockSlide Engineering with bushwackerdWww
  1. Neohiofan
    Neohiofan Well-Known Member
    First Name:
    Pete
    Vehicle(s):
    2019 JL Rubicon
    Oct 28, 2018
    Cleveland, Ohio
    117
    Liked:
    46
    #1 Jun 25, 2019
    I ordered Rockslide Engineering slider/steps. I also have Bushwacker sill covers and would like them under the rockslide Rengineering steps. I know during install you have strip on the rocker panel that gets put on To absorb hits. Can I use the Bushwacker for that or should I put that strip on the Bushwacker sillguards or under them?
    Maccabees likes this.
  2. cwadle
    cwadle Well-Known Member
    First Name:
    cameron
    Vehicle(s):
    2019 Granite JLUR
    Jul 11, 2018
    Rochester Hills, MI
    238
    Liked:
    116
    Garage Profiles:
    If Im understanding you correctly, you are worried about damaging the rocker panels above the pinch seam. If so, then during installation they provide a piece of protective foam to prevent rubbing and paint damage. If you're looking for a more permanent solution, you should be able to fit a thin protective layer atop the rocker panel.
  3. Fire Burns
    Fire Burns Well-Known Member
    Vehicle(s):
    2018 JLUR 3.6
    Oct 15, 2018
    CA
    605
    Liked:
    487
    Use the sill guards from RSE. Guaranteed to be compatible with their sliders and a whole lot more durable than the plastic Bushwacker stuff
    urr2slo and cwadle like this.
Loading...
Share This Page
