Twowheels19
- Dec 20, 2021
- Chester County, PA
- ‘02 GMC Sierra 8.1, ‘22 JLURD
Although I only removed a small wedge from the front, they are definitely able to be trimmed and caps reinstalled.You could trim probably 6-8” off either end without affecting the structural integrity. There’s no fasteners at either end beyond the ones in the pinch welds below the doors. The performance rails use exactly the same fasteners as the factory Rubicon rails, and are built the same way, just wider.
This photo is the factory rails, however the performance set is identical other than being a wider profile. Sort of a 2x4 rather than 2x2. If you trimmed the ends the plastic end caps should pop right back in.
