RebelOffRoad
- Evan
- Jul 28, 2016
- Website
- www.rebeloffroad.com
- 2018 Jeep Wrangler JLU / Jeep Wrangler Rubicon 392
- Occupation
- Jeep Builder
View Deal:
https://rebeloffroad.com/rock-slide-engineering-jl-unlimited-4-door-step-sliders/
NO-DRILL FACTORY BOLT ON INSTALL is here!
Our steps have been updated to make them quicker, quieter, and stronger along with a completely factory mounting install. With an all new designed motor, a larger step, added interior gussets, and redesigned arms make this step the most functional power step on the market!
- FACTORY MOUNT INSTALL!
- NO DRILLING REQUIRED FOR STEP SLIDER INSTALL.
- NO NUTSERTS REQUIRED.
Behind the step aluminum bumpstop, which adheres with VHB double sided adhesive, disperses any forces against the entire side of your vehicle if you hit the step instead of damaging the body.
- Functional step incorporated into a functional rock slider that deploys when the door is opened.
- Trail rated to 5 and below. Trails 5 and above require additional Skid Plates (AX-SS-SP-JL4 Sold Separately)
- Step can hold up to 650 LBS and feature a 12" drop when deployed.
- CNC laser cut from 11 gauge steel.
- Full pinch seam protection.
- Made in the USA.
- Powder coated textured black.
Rocker guard sold separately. AX-SS-RG-JL4. Not required for install.
