jeepddy
- Ed
- Jul 10, 2018
- los angeles
- 2018 Jeep wrangler JL
Selling my lift kit from my JL Sahara, used but in great condition. never been off roading only used for daily driving............... please see pictures below and description.... local pick up in southern California.
i have the Bolt-on rear track bar relocation bracket but its not pictured in my photos.. also will include JKS front sway bar links quick disconnects.
looking to get $700 for a quick sale ..................local pick, will not ship
The Rock Krawler JL 3.5 Adventure Series 1 Mid Arm System was designed for those who want an easy bolt-in installation, excellent on-road ride and the durability and off-road performance you expect from Rock Krawler Suspension. The Adventure Series fixed lower control arms offer a total of 60 degrees of misalignment that greatly reduces the bind inherent in JL factory lowers. Rock Krawler’s industry leading triple rate coils give you 3.5” of lift to clear up to 40” tires, depending on model, and improve the on-road ride over the factory linear rate springs. All Rock Krawler JL systems include correction pads that help minimize the spring bow inherent in the factory set up. The provided track bar geometry corrections, both front and rear, lets you perfectly center the axles so there is no compromise in on road handling.
System Benefits:
Sport and Sahara with Full OEM Fenders
37” Tall Tires (3” Bump Stop Height Recommended)
Sport and Sahara with Trimmed or High Lined OEM Fenders
38” Tall Tires (3” Bump Stop Height Recommended)
Rubicon with Full OEM Fenders
37”/38” Tall Tires (3” Bump Stop Height Recommended)
Rubicon with Trimmed or High Lined OEM Fenders
40” Tall Tires (3” Bump Stop Height Recommended)
Wheel Fitment:
Sport and Sahara Wheel Fitment Recommendations
37”/38” Tall Tires - Recommend 3.5” of Back Spacing
Rubicon Fitment Recommendations
37” Tall Tires – Recommend 4.5” of Back Spacing
40” Tall Tires – Recommend 3.5” of Back Spacing
General Notes:
*All lift heights based on Rubicon Models
*Recommend a new front C.V. driveshaft for all front shocks with max. extended length greater than 29”
System Benefits:
- Complete Bolt in System
- Excellent Highway Ride
- Improved Off-Road Ability
- Triple Rate Coil Springs
- Front & Rear Spring Leveling Pads
- Lifetime Warranty on All Hard Parts
- Upgradeable to Rock Krawler JL Long Arm
- Jeep remains level on all 4 corners
- (4) Triple rate coil springs
- (2) 2.25 RRD Spec Front Shocks (Travel Length: 12.0")
- (2) 2.25 RRD Spec Rear Shocks (Travel Length: 12.0")
- (2) Front lower Adventure Series control arms
- (2) Front spring pads
- (2) Rear spring pads
- (2) Extended rear sway bar links
- (1) Bolt-on rear track bar relocation bracket
Wheel Fitment:
General Notes:
