Roky
Since I’m not familiar with the MC bumps, I would cycle the suspension to be sure. You wanna make sure that your shocks aren’t bottoming out as well as check for rubbing at full stuff.I recently installed this kit with 35's. I also used RK's bumpstops kit along with MC durosprings. The RK directions said to use 2 bumpstop pucks in the front and one in the back with the extension bracket with 35" tires. I called metal cloak and they said there durosprings don't compress completely flat like the stocks on do they said they compress to about an inch. So I only used 1 bumpstop puck in the front and only the extension bracket in the back since the RK pucks are about an inch thick. You guys think I'm ok? I have not tested it out to see if I would rub the fender on a full flex but just from looking at it seems like it still might rub.
