Rock Krawler 2.5 Adventure Front Adjustable Track Bar won't fit
  1. calliejake
    calliejake Member
    Vehicle(s):
    Current JLU Rubi and 98 TJ. Past12 JKU Sahara, 92 Sahara
    Feb 10, 2018
    MA
    Liked:
    Any suggestions for getting the front track bar actually into the axle side bracket? It's too wide....
  2. wbee
    wbee Well-Known Member
    First Name:
    Wade
    Vehicle(s):
    2010 JKU, 2018 JLUR
    Feb 1, 2018
    Spring, TX
    104
    Liked:
    115
    I had to use a pry bar and carefully spread the bracket just slightly to get mine in.
  3. Martindfletcher
    Martindfletcher Well-Known Member
    First Name:
    Martin
    Vehicle(s):
    Ducati 1299s, 2018 JLUR
    Jan 3, 2018
    San Diego
    1,397
    Liked:
    1,214
    Same, better than it being too loose.
  4. Rock Krawler Suspension
    Rock Krawler Suspension Well-Known Member
    Rock Sponsor (Level 1)
    First Name:
    Tech Support
    Vehicle(s):
    Red JLUR, White JLUR, Yellow JL (3 so far), Bikini Diesel JLU, Billet JT, Hydro Blue JT
    Oct 15, 2017
    Waterford New York
    452
    Liked:
    392
    The bracket by design is 1.625", many factory brackets are crushed slightly, likely from the factory over-tightening the bolt. I typically use a crescent wrench to open the bracket back up to its designed width or, as others have suggested, a prybar will do it.
  5. OBJLU
    OBJLU Well-Known Member
    First Name:
    Henry
    Vehicle(s):
    2018 JLU Rubicon
    Jul 23, 2018
    Los Angeles
    126
    Liked:
    47
    Cresent wrench worked for me.
  6. Jimbo1226
    Jimbo1226 Member
    First Name:
    Jim
    Vehicle(s):
    2015 JK, 2018 JLUR
    Jul 19, 2018
    In a Jeep
    Liked:
    Me too, no big deal, I’d much rather it be tight than loose
  7. OP
    calliejake
    calliejake Member
    Vehicle(s):
    Feb 10, 2018
    MA
    Liked:
    Thanks - the pry bar worked - was a little nervous bending a bracket. Next question, any ideas for the brake line brackets? Seems it would have been easier to "peel" them off when the bracket was still installed to the lower control arm...I've bent the crap out of it with channel locks, but can't get it "open" enough to get the brake line out...cut off wheel?
    I've installed a TJ and a JK lift in the last 6 months, but this one is throwing me...
  8. Martindfletcher
    First Name:
    Martin
    Vehicle(s):
    Jan 3, 2018
    San Diego
    1,397
    Liked:
    1,214
    I cut them with a dremel. Took long enough.. If I hadn’t had a “few” barley pops at that point, an angle grinder with cut off wheel may have been quicker.
  9. Rock Krawler Suspension
    First Name:
    Tech Support
    Vehicle(s):
    Oct 15, 2017
    Waterford New York
    452
    Liked:
    392
    You can cut them off like @Martindfletcher suggested. Otherwise, a solid set of vise grips on the bracket and a small prybar to start opening the bracket, then move to vice grips and channel locks.
Loading...
Share This Page
