Rock Hard front LCA skid question
Instaurare
Arizona
2018 JL 2.0 turbo
I recently installed rear lca skids, but am wondering if the addition of front lca skids will require an alignment? Thanks for any input.
ExitLeft
Wes
Philly ā€˜burbs
2003 Jeep Wrangler TJ
No alignment needed as nothing changes. Just bolt them on and go. Torque the bolts properly with the wheels on the ground of course.
Instaurare
Arizona
2018 JL 2.0 turbo
Thanks for your reply. The install instructions say that it is not compatible with the alignment cam or cam bolts, does this have any effect?
The next step after this will likely be 35s on the JLR, but without a lift. Am I right to expect that I will not need alignment with the larger tires? Thanks again for the advice!
ExitLeft
Wes
Philly ā€˜burbs
No alignment needed if youā€™re not lifting. If youā€™re stock you donā€™t have to worry about cam bolts. Cam bolts are used when your bolt holes are slotted to allow for adjustment. A lot of people donā€™t use cam bolts as they can shift/loosen Due to the slotted holes. Adjustable control arms are preferred to cam bolts, but since youā€™re not lifting you wonā€™t need to worry about that. Larger tires alone donā€™t need an alignment
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 911 / 2013 E92 M3
...huh?
I have the RH LCA skids on... nothing further needed. The only problem I had was getting the passenger-side to play nicely with the FAD skid.
ExitLeft
Wes
Philly ā€˜burbs
What brand FAD skid are you using? I think RH makes their own, but I've heard MetalCloak's doesn't play nice with the RH control arm skids.
melendez69
Marc
Waxhaw NC
...huh?
I replaced the stock with an Artec. Heftier than the flimsy stock.
JL2021guy
JL2021guy
Daly City
2021 Jeep Wrangler rubicon 3.6
Jeep fun
How did you get artec fad to work with rock hard lca skid ?? Did it just simply work?
melendez69
Marc
Waxhaw NC
...huh?
I didn't... it doesn't play nice, so I don't have a skid on that side. I have the MC skid but I'll need to replace the steering stabilizer.
JL2021guy
JL2021guy
Daly City
Jeep fun
So you tried artec fad skid but it didnā€™t work with rock hard skids ?
Just trying to be sure I understood.
Or did you mean you never tried the combo together
melendez69
Marc
Waxhaw NC
...huh?
The RH skid will not fit with the Artec... I tried...and tried... The skid won't fit in the gap between the LCA & the Artec. I even tried shaving it down & gave up.
JL2021guy
JL2021guy
Daly City
Jeep fun
Got it
Thanks a million for your help
