bohnster
- Brad
- Oct 4, 2021
- Franklin, TN
- 2021 JLU Sahara Altitude GCM
- Occupation
- Bourbon Taster
It can be confusing and there's not a lot of info on that approach because most folks use remotes/switches for rock lights. In the footwell, there are two different lights and two different wires, and that's why you have a courtesy light dial on your headlight control panel to control the courtesy lights. Correct on the fuse though because it's an mcase. In your footwell, the right light comes on when you fob click or open the doors; the left light is on (and is much dimmer) when the headlights are on, unless you dial that courtesy light dial all the way down. I'm about to wire up some Oracle rock lights under my sliders and some Oracle led strips in my footwells. I will tap both into the same footwell wire (yellow/brown I believe). You can check with Oracle Lights, Quadratec, etc. as well. I confirmed the rock light approach with Oracle after watching the install video of their Sidetrack light system.It certainly helps clarify. For me, then, back to the drawing board on tapping the circuit that the interior dome light are on, or something of the sort. Doesn’t look like it can be done from the fuse box either, as the only thing I could find on that was a circuit for “interior lights”.
Am I wrong to assume I’m the only one who’d like the rock slider lights to functionally operate like the dome light?
