ROAM Side Steps light wiring (or any step lights with door open illumination.)
TTEChris
TTEChris
Houston, TX
www.tankcustoms.com
2018 JLU Rubicon & Sport(Wife)
  • Thread starter
  • Thread Starter
  • #226
Thanks for all your help, but may I add something?
I just spent the last few months trying to get my LED Roam lights to shut off automatically, to no avail.
I would go back and re-read your uxcell relay instructions, but no success?
Then it occurred to me that you may not have had the optional factory LED Light package, but I do
Once I wired the Roam LED's directly, by-way-of a fused link to my interior LED wire, all was well!
I suspect that my factory interior LED lights didn't draw enough power to trigger the disconnect function of the uxcell solid state relay?
With my Roam lights wired directly to the interior lights without a relay, my Roam lights still dim quite nicely in the same fashion as the interor dimming qualities.
uxcell ASH-25DD 3-32VDC to 5-250VDC 25A Single Phase Solid State DC-DC Relay
Strange,
I've done the install on both LED and Non LED package Jeeps. Really the main difference isn't in the LED package but whether or not you Jeep came equipped with the "mood lighting". On vehicles with it there are three wires to the footwell light rather than two. In both instances the wire color I tapped into was the same and the step lights functioned the same.
DonBindas
Don
Naples, Florida
Ordered a 2020 JL Rubicon Unlimited in Bikini with Dark Saddle Leather on 7-8-19 and was delivered by Criswell 8-22-19
KBB Analyst
Strange,
Yes, strange indeed, as I followed the instructions exactly and used the same relay that was recommended from Amazon?
But now that I am thinking about it, why would I even need to use a relay to power LED's to/from a LED circuit?
CaddyshackGopher
North Dakota
2019 Sting Gray JLUR
Without the relay mine sounds like a swarm of locusts are having a party under the hood each time the lights go on/off
DonBindas
Don
Naples, Florida
KBB Analyst
I agree with your logic, but my experience tells me to skip the relay on LED lights when tapping into a LED feed wire.
smklaw
SW FL
2019 Rubicon
Finally got my lights done this past weekend. For the life of me I could not get through the passenger side pass-through so I ended up running across through the cross-brace and then took both sides through the driver's side and connected to the under dash light. Works perfect.
DonBindas
Don
Naples, Florida
KBB Analyst
I love those red lights on a red vehicle.
Sorry to hear about the wiring issue.
I found it to be a neater solution to run the power lead wire from the left side to the right by coming up the side of the engine bay and under the inner lip across the hood opening's rubber strip near the windshield.
Mmorreale
Houston, Texas
2020 JLU Sahara Altitude 3.0 EcoDiesel
Retired (disabled) Firefighter
I’m having trouble with my lights. I tapped my cyclone lights into the footwell lights to make blue footwell lights and outside entry lights. At night everything stays on because the factory footwell lights go really dim and don’t turn completely off. How do I fix this? Help!
BRC10
Ben
Centreville, Virginia
2019 JLU Sport
Read my reply to someone on the previous page. Same problem. You probably have both the footwell lights and the mood lights (they are different), and you tapped the wrong one.
Mmorreale
Houston, Texas
We switched it. It’s fixed now. Thank you!
arok99
Rocklin, Ca
2018 JLU Rubicon
After a year and a half of having the rails I finally installed the LEDs and boy are they bright! Has anyone considered adding a resistor to reduce the brightness?
jwalt
Idaho
2019 JLU Rubicon, 2004 TJ Rubicon, 2017 Cherokee
I considered doing it with mine. I was going to put in a rotary potientiometer so I could manually adjust the maximum brightness and install it under the hood near the solid state relay. I figure once it was installed and adjusted I wouldn't really mess with it. Just make sure to get one large enough to handle the heat dissipation without burning out. The power P in watts (W) is equal to the squared current I in amps (A) times the resistance R in ohms Ω
arok99
Rocklin, Ca
2018 JLU Rubicon
That's actually the same route I took, I set the brightness to where I want it and left it.
