ROAM Side Steps light wiring (or any step lights with door open illumination.)
AgentTML
Tri
CA
JL Rubicon (2018), Honda Pilot Touring (2010), Ford C-Max SEL (2013)
Thank you @TTEChris for your detailed write-up. I am waiting for my steps to come in. I am a total newbie about all this car mechanics/electrical stuff so all this is new learning for me. I have a question about waterproofing the connections...how do you make it water proof such that in the event of water fording in the Jeep with the water splashing all over the steppers, will it hold up to that amount of water?
Thank you.
Twistedfab
Greenville, SC
20 JLUR
Thank you.
I used shrink wrap and waterproof connectors.
TTEChris
TTEChris
Houston, TX
www.tankcustoms.com
2018 JLU Rubicon & Sport(Wife)
  • Thread starter
  • Thread Starter
  • #168
Thank you.
I also used marine grade shrink tubing and waterproof electrical connections that I soldered together with the wire like @Twistedfab mentioned.
AgentTML
Tri
CA
AgentTML
Tri
CA
AgentTML
Tri
CA
I'm not sure if I want to install the lights and deal with all the electrical work. I'm thinking of just installing the rails for now and then in the future, install the lights. Question: Is it possible to install the lights with the rails mounted on the Jeep or would I have to take them off and then do the wiring?
TTEChris
TTEChris
Houston, TX
www.tankcustoms.com
  • Thread starter
  • Thread Starter
  • #174
It would be MUCH easier to wire them off the Jeep. Really once you have them mounted and the brackets aligned, it's only 6 bolts to remove them and set them on a table. If you have an impact gun they can be removed in less than 5 minutes.
AgentTML
Tri
CA
Ok, so it seems like an easy process to remove them. Thank you!
pichenet
Dennis
Michigan
JLU Sport S
If you use locktite - which I think the roam guys recommend in their instructions - it might take a min to remove depending on your experience with the stuff.
CO_Mojito
Larry
Colorado Springs, Colorado
www.instagram.com
2019 JLUR 2.0L Turbo Mojito
IT Enterprise Systems Architect
Just ordered my sliders. Looking to order a set on Onzium LED bolts. It seems that the 2019 version is now all IP68 rated, even the 1w aluminum ones based on their site. Any preference on with or without lenses? I was leaning towards the 3w stainless, but it seems the 1w is more then bright enough, and now that they are both IP68 rated, seem to be fine. So I will need to purchase 8 LED bolts, some terminal connectors, the solid state relay, do i need a fuse holder?
Shawn
Maine
2018 Sting Gray JLU Sport
I just wired mine with the steps on the Jeep. However, as others have suggested, it probably would have been easier to have taken the steps off. I did take the recommendation of making my own wiring harness. I followed these instructions and I'm very pleased with the outcome. Well worth the time and effort.
MadDog27
Jon
Cameron, North Carolina
2018 JL Sport S MT 6 Spd, 2019 Subaru Ascent
I think you may have answered this but Im thinking of just getting a standard auto relay from the parts store and using that. With it being under the hood, would you hear the clicking all that much? Would this work or is it better to use the solid state relay?
Great write-up and am looking forward to trying this out.
TTEChris
TTEChris
Houston, TX
www.tankcustoms.com
  • Thread starter
  • Thread Starter
  • #180
I couldn't live with the sound...
It sounds like a bunch of angry locusts under the hood until the dimming stops. I'm also not sure how long the relay would last as it is cycling on/off very quickly until a steady voltage is achieved.
You could use one temporarily, but I would get the solid state relay long term.
