ROAM
- Mar 12, 2018
- Texas
- Website
- www.roamoffroad.com
- JL Rubicon
ROAM JL Extended Capacity Fuel Tank: 4.25 more gallons more than stock (JLU 4 door) on the main tank and another 20.75 gallons with an auxiliary tank.
- We've built the main tank to utilize all available space.
- Currently only compatible with the 3.6 pentastar and not the 2L turbo because of the ESS system. 2L turbo compatibility TBA.
- Currently only compatible with JLU's (4 door), 2 door JL compatibility TBA.
- Utilizes and retains the OEM fuel hat and bucket/pump assembly. OE Fuel float functionality is unaffected and still accurate.
- Fully seam welded 316 Stainless Steel construction with integrated 1/2" Skid Plate for additional protection against punctures and impacts.
- Every tank is pressure tested to 150 psi and absolute vacuum.
- Ethanol and multi-fuel compatible.
- Although this fuel tank meets all of the regulation standards for emissions set by the California Air Resources Board, the U.S. Department of Transportation, and the Environment Protection Agency, this fuel tank is not currently available for sale or installation in: California, Massachusetts, New York, Oregon, and Washington, and the District of Columbia.
<Images are attached below.>
