Left Field
- Tim
- Aug 5, 2020
- Western WA
- '67 RS-SS Camaro, 2021 JLUR392
Just finished a 5100 mile / 24 day road trip and thought I'd share some of our 392 JLUR specific observations.
The route was mostly bouncing around the southwest: Depart Seattle - Orange County - Glamis - Phoenix - Prescott - Sedona - Flagstaff - Page - St. George - Zion - Valley of Fire - Death Valley - Las Vegas - Mojave NP - Joshua Tree -> Seattle.
Pretty much rookie compared to @wibornz but working up it
The trip avoided interstate except a couple short stretches of I-15 and I-40, otherwise two lane highway and around 250 miles off-road (Glamis Dunes, Schnebly Hill, Titus Canyon, Mojave Trail, Wild Horse Canyon, Macedonia Canyon, Berdoo Canyon, Old Dale Road / Brooklyn Mine Road).
Mostly stock vehicle - only a few non-performance mods so far :
- Maximus3-Rhino roof rack
- Teraflex rear hinge gate support and tire carrier
- Rock Slide Engineering 3.0 power steps
During the trip I stopped at a closed state weigh station; total weight (with occupants & gear) was 5850lbs ( 2900lbs F / 2950lbs R ).
Total fuel economy for the trip was around 15.2 mpg (measured); this was about 3-4% lower than indicated by the vehicle (approx. 15.8 mpg). Most speeds were 65-70 mph. At high elevation, no wind, 65 mph on the flat the engine would spend most of the time in 4cyl mode and get between 17-18 mpg indicated. Any other condition it was running on all 8 unless coasting. With headwinds and/or at higher speeds the gas mileage indicated would dip to 12-13 mpg. Best mileage for a tank was 17.1 mpg (measured).
Although I had a 5g steel jerry can along, fuel anxiety and range turned out to be largely a non-issue. My typical fill was between 280 & 300 miles which was around 4-5 hours driving. I still am pursuing the idea of an aux. fuel tank for the backcountry. One of our campsites was over 100 miles round trip to get more fuel. The fuel light usually came on around 18.5g out of total 21.5g capacity. Most I ever put in was just over 20g. Info page at that point indicated a range of 15 miles. Seems fair.
It was great driving a vehicle that could transition from sand, rock, snow or water fording, then pull back on the highway for an effortless merge and good highway manners. The paddle shift hill descent mode worked really well on steep rocky descents. The only anomalous behavior (not 100% sure) was easy running on some sand woops on the Mojave trail (in 4-auto), thought I heard the ABS buzzing a brake now and then. I turned off stability/traction control and never heard it again. Note taken. Most of the rest of the offroad I switched to 4-PT, figured it would save some wear on the T-case clutch pack. No lockers needed on this terrain.
Great vehicle, looking forward to the next trip!
