- Todd
- Aug 26, 2018
- Website
- www.prodigyperformance.com
- 2018 JL Shara 3.6 TurboCharged~2012 JK Sport TurboCharged~2017 Dodge Challenger 3.6 Twin-Turbo
- Occupation
- Director of Sales & Marketing
Many people think turbo's only mean speed and that is not the case. The V8's have more weight and not always a great solution for "more power". When you think of offroading, what people need or want is both torque and horsepower, but mainly torque. No other forced induction solution is more efficient at achieving both of these than that of a turbo. Which is why Jeep introduced a 2.0LTurbo option and not a Hemi option. Keep in mind that there are many variables in the design of a turbo solution. At the drag strip, very large turbo's are used because of when they want the power, so they have turbo lag. The smaller the turbo, the less time it takes to spool and therefore there is less lag. The 2.0L Turbo is very small and virtually no lag. We are somewhere in the middle. We want our customers to be able to reach highway speeds and be able to use cruise control without continuous downshifting. In lower RPM's, say below 2500, the Jeep is great as designed and you don't need more power, so our system is designed to complement the vehicle.Not familiar with formula 1 or Hybrids. In any case damaging the power unit is a pretty vague statement. I'm not trying to give you too much crap but from the searches I've done there doesn't seem to be much info out there on the 3.6. In most other platforms when people want more power they just buy something that already has a hemi in it. In jeeps most people care about offroad capabilities more than speed.
In my other post I ask how much hp on 91 octane at 12psi but thinking about it you probably can't get to 12psi on 91. What boost does your kit provide to safely run on 91? From there I don't see why someone couldn't add meth and bump it up a few psi.
As far as fuel system goes, does adding boost automatically require new fuel injectors and fuel pump? I have seen info about the stock fuel system either.
We send our Jeep Wrangler kits with 6-8lbs of boost depending on which model you purchase. We require 91-93 octane for all levels of boost and what you can expect is a fuel economy gain as much as 5MPG. If you choose to adjust the boost levels, you could gain about 20HP per 1lb of boost, but we don't recommend that you do this if you want to maintain a long life expectancy of your engine.
There are many variables with the fuel delivery system and we have designed our kit as it comes out of the box to work with the vehicle as stock as possible. Any parts that would need to be changed or upgraded are provided. In this case, we provide flow matched fuel injectors with a higher flow rate. Nothing else needs to be adjusted.
I want to help you achieve your Jeep dreams. Let me ask you a question... What are you trying to achieve with your vehicle, where are you going to be driving it and how are you going to drive it?
