Rhino Rack / Currie Rock Jock JLU Wrangler Build [SEMA 2019]
Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
Ya I'm interested in that Air Compressor setup!!
The remote filter, switch, and fitting component looks new. Here is the mounting bracket AAL sells for the dual compressor.
KeithM
Keith
Anaheim Hills, CA
19 JLUR, 06 Duramax, e39 Touring
Software
So a remote reservoir damper AND a coilover remote reservoir damper on each corner?
Common setup for a desert rig. Second damper is a position sensitive bypass. The external bypass tubes won’t work with a coil. Could have gotten fancy with internal bypass, but if you are doing a lot of desert miles and have the room the more fluid the better to dissipate heat.
balan
Brady
Pittsburgh
heraglobaltech.com
2019 Moab Punk'n
Engineer
Qurtyslyn
Curtis
Utah
2018 Mojito JLUR
The coil over is likely just being used as a coil carrier with light, if any, valving as well, the Bypass should be taking care of all of the shock duties.
Bestop
Peak Sponsor (Level 2)
The Bestop Team
Louisville, CO
2010 JKU
I'm in the same boat - tried to contact Rhino Rack customer support - no answer at all. Would really appreciate some info.
The Rhino Rack for Sunrider that we carry is for the JK and requires their backbone system.
With the JL the existing backbone system will have to be reengineered to work. Given this the Rhino Rack for Sunrider could conceptually work on the JL but there isn't a way to support it.
We've not heard any ETA from Rhino Rack on the JL so, unfortunately, we can't shed any light on their plans on this front either.
- the Bestop team
www.bestop.com
