Review of Fourteen 2.0T Oil Filters
NWJeepr
Tieton
2023 Rubicon XR
Nice writeup. Just joined! I recently purchased a CPO 2021 2.0T with ~56k.
The 2.0 engine will appear wildly overfilled if you don't check the oil 5 minutes after a warm shutdown. The procedure is listed in the owner's manual and it's one of those "gotchas" about owning a 2.0 engine.
It's also wild that there's a Stellantis-knockoff of a proper Mopar filter now. What in the actual hell is going on! lol
mots
Midwest
2021 Wrangler Sport S 2.0L
Thanks, it wasn't that simple unfortunately. I drained 6 quarts.
PunksJL
Paul
Colorado Springs, Colorado
2025 Rubicon X 2.0T Bright White
Too bad no Purolator filters were included in this comparison. The Purolator Boss and Purolator One are good filters.
CarbonSteel
CarbonSteel
IMO a synthetic filter should have more surface area than a cellulose filter due to high flow requirements in having smaller diameter filtration.
I have never seen that in practice--look at the FRAM Endurance versus the SuperTech. It is clear the SuperTech has more surface area and media--but the FRAM wins on efficiency.
It's all about the media efficiency...
CarbonSteel
CarbonSteel
Purolator = Mann+Hummel. They had a serious run of bad non-Boss Purolator filters a few years ago (tearing media at low mileage). I may go grab one of each--I think AAP sells them near me.
JLUR Farout
M
SE Washington
2024 JLR X 35" Package
1/2 quart. Due to my oil growth chasing problem I have trialed this dozens of times. If you do the oil change text book per the manual, then check in 12 hours, it is 1/2 quart. That is how much stays on the top end of the engine to drain back down.
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
I previously used the XG10060 on my daughter’s 2020 Jeep Renegade. It seemed to be of a good quality and was always available.
My wife bought a new 2024 Jeep Compass Limited last August, and I dropped the oil & filter in it around 800 miles, using Pennzoil 5W30 that met specs and an MO339 filter.
It is now at 4,200 miles, and will be getting another oil change and a tire rotation at 5,000 miles….but I’ll be going with the FRAM FE10060 from here on out.
CarbonSteel
CarbonSteel
@PunksJL - now updated with a Purolator One and a Purolator Boss.
Punknhed
Virginia
2023 Punkin Rubi XR
interesting...... this would explain why when i drain my oil it always seems like not enough comes out.... should have read the manual lol
CarbonSteel
CarbonSteel
I run the Endurance in my Bronco too. It has a cartridge filter like the 3.6L (though the housing is all aluminum unlike the FCA design). For the quality and the cost, they are hard to beat.
JLUR Farout
M
SE Washington
If you put 5 QT in, you should get 5 QT out. I was getting more than 5 QT out due to oil dillution from fuel. I've not heard where a lot of extra oil stays in the engine during a drain, say like on an EcoDiesel or a Duramax. The dipstick reading will vary depending on when you check it...because Jeep made a dipstick into a rubix cube.
Punknhed
Virginia
2023 Punkin Rubi XR
ill have to pay attention tomorrow or monday when i do my oil. but it seemed like i wouldnt quite get a full 5 out of it.
