RIVICON
- Dennis
- Mar 23, 2021
- Wesley Chapel, FL
- 2020 Rubicon, 2006 Tacoma, 1991 Z28 406ci Turbski
Greetings fellow Jeepers. I just wanted to share my experience with transmission shift points and larger tires. I'm sure alot of yall are having this problem with hanging shifts or losing 8th gear after going with larger tires. My wife's 2020 JLUR has been lifted 2.5" with 35's. I recalibrated the speedo using the Jscan app and bypass cable with a Vlinker MC+ bluetooth OBD adapter. We recently made a roundtrip to PA from Florida and the speedo and GPS were dead on, however, I noticed the shift points were off. I seemed to have lost 8th gear on the highway and sometimes it would hang in 6th or 7th gear on a flat road. I'd either have to let off the throttle a little or do it manually to get into the next gear. It seemed to be a chore instead of a road trip. Well yesterday I was tooling around in Jscan and saw a TCM module(Transmission Control) and found an option to reset shift adaptations so I reset it and went for a test drive on the highway and lo and behold I got my 8th gear back. Not only that but it shifts way better and doesnt hunt for gears. I'm assuming the adaptation that was in there was learned for the factory 32" tires and now it's relearning for the 35" tires. I've heard of some people going to the dealership to get a reprogram and I think all they are doing is resetting the TCM adaptations so save your hard earned money and try out this method and see if it works for you ?
