LLRubylady
just curious if this is a mod that will have value in resale?
It feels different alright. feels heavy. I'm considering change to the KO2 because the NIttos are like 13 pounds per tire more. Don't know if i should try that first or just go back to stock and wait.Nice bumpers, wheels, tires, visual/appearance mods can help resale. Regear will be a total loss.
I know that you went from 33s to 35s on your Rubicon. The Rubi is geared deep. Honesty, you are not going to feel a difference with that small of a tire size difference. Most likely you worried about it and now you think it feels different.
really? How would 4.56 gears make it feel worse?That's really not much of a weight change, gearing would make it feel even worse.
29 pounds isn't a heavy rim. Stock is probably close to that.really? How would 4.56 gears make it feel worse?
also, actually in addition to the 13 lbs for the tires i have KMC rims which are 29 pounds vs. stock rubicon rims.
Yea, like he said, 4.56 is barely different from 4.10. Higher gearing will make you feel sluggish, the high gears are just necessary to keep the engine RPM in the power band at reasonable gears.really? How would 4.56 gears make it feel worse?
