Replaced my stock halogen fog/DRL/Signal lights with LED.
  1. JSFoster75
    JSFoster75 Well-Known Member
    First Name:
    Vehicle(s):
    2018 Jeep Wrangler JL Unlimited Sahara x2
    Oct 6, 2019
    Bluff City, TN
    351
    Liked:
    297
    Garage Profiles:
    blnewt and Will_Jeep like this.
  2. Will_Jeep
    Will_Jeep Well-Known Member
    First Name:
    Will
    Vehicle(s):
    Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
    Feb 27, 2019
    Atlanta
    124
    Liked:
    114
    Looks good, thanks for sharing!
    I have been debating upgrading my DRLs and turn signals, your pics help :like:
    JSFoster75 likes this.
  3. blnewt
    blnewt Well-Known Member
    First Name:
    Vehicle(s):
    2019 Jeep JL Sport S, 03 Toyota 4Runner, Infiniti G37, Toyota T100 (Retired 74 CJ-5, 80 CJ-7)
    Oct 8, 2018
    New Mexico
    1,568
    Liked:
    1,331
    Nice update, did your fog light connectors require any trimming of the socket tabs? Mine fit ok but had to "modify" them a bit :(
    Arterius2 and JSFoster75 like this.
  4. OP
    JSFoster75
    First Name:
    Vehicle(s):
    Oct 6, 2019
    Bluff City, TN
    351
    Liked:
    297
    Garage Profiles:
    I was afraid they might, but they fit in perfectly.
    blnewt likes this.
  5. df007
    df007 Well-Known Member
    Vehicle(s):
    2019 JLU Sahara 2.0
    Sep 11, 2019
    154
    Liked:
    108
    Did you get any hyperflash or errors? Want to do the same but trying to avoid buying a Tazer.
  6. OP
    JSFoster75
    First Name:
    Vehicle(s):
    Oct 6, 2019
    Bluff City, TN
    351
    Liked:
    297
    Garage Profiles:
    No errors at all, but mine didn't have the LED package from the factory and the bulbs I bought were specifically for the JLU. Follow the links in my OP for the same setup. :)
    df007 likes this.
  7. Will_Jeep
    First Name:
    Will
    Vehicle(s):
    Feb 27, 2019
    Atlanta
    124
    Liked:
    114
    WranglerMan, JSFoster75 and blnewt like this.
  8. Will_Jeep
    First Name:
    Will
    Vehicle(s):
    Feb 27, 2019
    Atlanta
    124
    Liked:
    114
    @JSFoster75 how are these holding up for you?
    I am getting an intermittent error code on one of the turn signals, which results in hyper flash when it happens.
    Looking around, it seems that most of the replacement bulbs also require resistors, which I am not sure that I want to install.
    I would welcome the thoughts of others.
  9. OP
    JSFoster75
    First Name:
    Vehicle(s):
    Oct 6, 2019
    Bluff City, TN
    351
    Liked:
    297
    Garage Profiles:
    it’s been about six weeks and I’ve not had any problems at all.
  10. Prestige Billet
    Prestige Billet Well-Known Member
    First Name:
    Eddie
    Vehicle(s):
    2012 JKU
    Jan 6, 2019
    82
    Liked:
    @JSFoster75 The DRL link above says they fit the 2019 JL, but the Alta Fog Light bulbs say they do not fit? Can you confirm it is the correct part number? Also do the bulbs "lock in" ? I read in another post that if the bulbs don't lock in they can fall out due do the extra weight of the LED bulb?
    Any info is appreciated,
    Thank you
    Eddie
    Prestige Billet
  11. WranglerMan
    WranglerMan Well-Known Member
    First Name:
    Will
    Vehicle(s):
    2018 Wrangler JLU Sahara
    May 8, 2018
    Katy Texas
    1,873
    Liked:
    1,190
    Occupation:
    Gas Pipeliner
    Garage Profiles:
    @JSFoster75 i to have a 2018 JLU Sahara so in regard to the DRL/Turn signals how hard were they to get to ?
    Also are you planning on replacing the rear tail lamps with the same supplier
  12. Will_Jeep
    First Name:
    Will
    Vehicle(s):
    Feb 27, 2019
    Atlanta
    124
    Liked:
    114
    @WranglerMan the bulbs are easy to get to, two 8mm bolt and Christmas tree panel clip, then peel back the inner fender. I have the same tail lights as those that this vendor sells, they too are an easy install, and I’ve had no issues with them.
  13. OP
    JSFoster75
    First Name:
    Vehicle(s):
    Oct 6, 2019
    Bluff City, TN
    351
    Liked:
    297
    Garage Profiles:
    They were easy to replace, took maybe 10 minutes per side (since I didn't know what I was doing), Just remove the two bolts and the clip, pull back the fender liner and from there it's a simple bulb replacement.
    I ended up going with the Spyder LED replacement tail lights, I love them!!!
    http://brpautodesigns.com/jeep-wrangler-jl-jlu-spyder-black-smoked-sequential-led-tail-lights/
    See my post here: https://www.jlwranglerforums.com/forum/threads/spyder-led-tail-lights.35444/
    Post #15
  14. OP
    JSFoster75
    First Name:
    Vehicle(s):
    Oct 6, 2019
    Bluff City, TN
    351
    Liked:
    297
    Garage Profiles:
    Eddie, the links I posted are correct, they do lock in, just a little difficult to get them to "click" into place. I've had them installed for 7 weeks or so and they are performing beautifully.
    Prestige Billet likes this.
  15. Prestige Billet
    First Name:
    Eddie
    Vehicle(s):
    2012 JKU
    Jan 6, 2019
    82
    Liked:
    Thank you
Loading...
Share This Page
