Repairing scratches on plastic mirrors
League City Texas
My side view mirrors are starting to look a bit beat up from quite a bit of brush damage. Is there any compound/formula that can be used to get scratches out of the plastic?
Thank you
OldGuyNewJeep
Don
CT
Thank you
You could have them vinyl wrapped. Would not cost much for such a small job.
IronScott
NW Arkansas
Maybe a very fine grit or wet sandpaper? I used some fine grit to smooth out some gouges I made on some of the plastic parts of the MOPAR steel front bumper. Worked fine.
Are there aftermarket mirror covers? I’ve seen them on JKs but not JLs. That would be another option.
plex
Cincinnati, OH
Weekend keyboard mechanic and beer drinker
The whole mirror assembly cost like a hundred buck, just buy two or three as backups, and keep banging them!
RockyMtJL
2019 JL Rubicon Unlimited
Did you find a solution? I am definitely needing to do some repair work as well.
MMalone
Michael
Lake Mary, FL
2023 Sahara 4XE White
Industrial Engineer
I got hit by shopping cart on plastic bumper. Did my research and tried compounds and back to black... but saw and read about heat gun. yes it works. Also removes oxidation.
RockyMtJL
How does the heat gun method work? Literally just heat it up and then? Thank you!
MMalone
Michael
Lake Mary, FL
Industrial Engineer
All I know is I watched several videos, and guess it melts the scratches back down a smooth state, take your time and keep moving the gun back and forth and up and down
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
Take them off, drop them off at the LineX dealer and have them spray them when they get a chance. They should cut a deal since their spray gun will already be loaded. Just make sure they tape off the area where the pivot point is.
