Remove sound bar center section - help
Goin2drt
Kentucky
18 Rubicon, 17 Grand Cherokee Trailhawk
Anyone have a YT video, pics or done the removal of the center section of the sound bar? I got some rock lights and want to mount them and wire them to the dome light for more light in the cabin.
Goin2drt
Kentucky
Well since no one had any advice I went for it after a little liquid courage and installed my interior rock lights. Center section is held on by 3 torq T-25 bolts. I circled the locations in the pic. The interior light just pulls straight down. I used a pry tool and you can see the metal clips holding it up in the pic. Then the center piece just pulls down. I spliced into the interior center light so the rock lights come on and off with that. The yellow/brown center wire is the switches power for the positive to splice into. Hope this helps some others.
I really like the output. I may do two more in the back by that dome light and the rear should be good to go.
Jeep Wrangler JL Remove sound bar center section - help 63A53F05-18B8-4C41-A1C0-E8ECEA1C26B5
Jeep Wrangler JL Remove sound bar center section - help DB24B2E1-772C-47EF-BA4C-AEF736AB6F4B
Jeep Wrangler JL Remove sound bar center section - help B17C3F50-34AA-4960-977A-0EC2A76B38CD
Jeep Wrangler JL Remove sound bar center section - help 56C8CFD8-B4B9-487D-9E86-86E58226EDE2
Jeep Wrangler JL Remove sound bar center section - help 284ED277-1F01-4131-9A78-B9F11EA7E886
Jeep Wrangler JL Remove sound bar center section - help 32949B8C-3209-42EB-9931-984163F0F9E9
Jeep Wrangler JL Remove sound bar center section - help 1EEF6513-08FB-4DFB-9225-CE26022C7F23
Jeep Wrangler JL Remove sound bar center section - help 2381DF4E-CDAD-4324-B9A3-1194BF08D1FE
Jeep Wrangler JL Remove sound bar center section - help A7CA4039-5B2C-4CF1-893D-96B0551B2D2F
jthoms1
Charlotte
2020 JLUR
Great write up! There is another thread similar to this but with far less detail. I ordered rock lights yesterday to this very thing. Thanks for the detailed tutorial.
zyt
Maryland
Mazda Miata
This is awesome. Thanks for the write up. Where do you connect the ground/negative? Is it that black wire? or yellow and blue?
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
Great write up! Thanks for posting!
Do the rock lights flood the front and rear seats well? Wondering if placing the lights one forward and one back so they are slightly angled up would be any better. However your installation is very clean and looks factory.
Goin2drt
Kentucky
This is the awesome. Thanks for the write up. Where do you connect the ground/negative? Is it that black wire? or yellow and blue?
Yep spliced into the black. Forgot to mention that.
They do. You will see when you pull off that center section doing what you suggest would be real custom. I was going to do that but you will see that center is actually two pieces molded together.
Htfan
Orange County, CA
Appreciate your wisdom on this! I've just added these lights to my Amazon list.
Htfan
Orange County, CA
Finally had some time today to complete this much needed project!
Very happy with the results.
One additional modification I made was utilizing switches to be able to turn one or both lights off if needed.
Jeep Wrangler JL Remove sound bar center section - help 20201122_151300_resized
Jeep Wrangler JL Remove sound bar center section - help 20201122_151201_resized
