Reminder: 5 quarts of oil to avoid oil overfill
californiajeeping
JLUR
First oil change today, drove an hour home . I always like to pop the hood when its home in the garage and help the engine cool on these hot summer days and look around after a service. Well first notable thing is the dipstick looks a tad out of place !!!! About 18” And a little spillage around the fill cap. So much for trying out my Jeep wave free oil changes. After it cools in the am I’ll check the oil level. Dealer paperwork says 6 qts . I’m hoping the tech left the dipstick loose and not that it’s so overfilled that the oil pressure popped it up that high.
Either way time to go back to doing my own oil changes.
( that’s really how I found the dipstick. I wish I was kidding)
Did you have 5 quarts written on your oil cap and they still put in 6 quarts or is that a picture of someone else's oil cap?
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
The problem is they don't read. They go on what they knew prior. Jeeps get 6 liters and therefore that is what they do. Even across a different engine type.....
moonpup
Massachusetts
2018 JLU Sahara
I had my second oil change done back on June 12th and the paperwork said quantity 5 for oil, but I just checked my dipstick and the oil is up and over onto the cable :mad:. Guess I'll have to drain some... or go back and make the dealer do it.
Solidaxle
Beautiful Ventura county California
2019 JL 2 Door Rubicon
The dipstick must have accidentally got caught on the workers sleeve or maybe his nose ring , because obviously they didn’t use it to check the oil. Someone would have realized it was overfilled.
Solidaxle
Smart for actually checking the oil not just the invoice, well done ! It’s been my fear that if people keep on complaining they won’t actually fix the problem by putting in the correct amount, they’ll just fix the paperwork to say 5 and shut people up and keep putting in 6 anyways.
VerservJL
NY
2018 Wrangler JL Sportaharacon
So I don't know if this has been mentioned before. I had my first oil change and asked the dealership why they did 6 quarts instead of 5 shown in the manual. I received a very reasonable response. They said the the 3.6 needs about 5.5 quarts, but the manual says 5 to keep people from over filling. They filled mine with about 5.5 and tossed the remainder as they had to bill 6 since it was opened. Seems sensible but who knows for sure.
Dkretden
Denver, CO
2020 JLUR 3.6L
Ask the dealership how many liters they would put in. Hint, it’s 4.73. Did Jeep specifically pick 4.73 liters to make sure that all those pesky European auto owners don’t put in 4.75 liters?
I think that Your dealership is full of crap. Write to FCA. Tell them the name of the dealership, the name of the person who told you this and ask if you could get on a conference call with Jeep and this dealership and see what is discussed.
DanW
If you properly measure it, 5 quarts is exactly what it takes. I've done 4 oil changes so far, and a single 5 quart jug is spot on.
blnewt
New Mexico
Just ask @cosine he knows!
Me too, but I've only done 2.
moonpup
Massachusetts
2018 JLU Sahara
True dat! Anyway, I drained just over a quart out of my Jeep this morning... what a bunch of knuckleheads :swear:
DanW
Make sure you are checking oil 1. When the engine has reached full operating temperature. 2. On level ground. 3. 5 minutes after engine shutdown. If you check a cold engine, or a warm engine right after shutoff, you WILL see a different level. (Not to the extreme that @XLMOJITO shows, though. That one is clearly WAY overfilled.)
californiajeeping
JLUR
Also, check your service invoice. Especially note when it says quantity 6.
Rufus
NYC
2018 2 door JL Sport 3.6 V6
After reading this thread, I’m going to call dealers BEFORE I go in for my first oil change and go to the one that says 5. Then after the change I’m going to double check the level and the invoice, right then and there on the lot.
Solidaxle
Jeep’s disappointed I’m doing my own maintenance and not using there “Specially trained technicians” lol
DanW
They have a particular set of skills...
