RedRock 4x4 HD Tailgate Reinforcement Panel Woes
jfarrell
Joshua
Mesa, AZ
2018 OB JLRU, 2018 4Runner
During my install I ran into some problems with a stuck bolt on the hinge of my tailgate. Turns out I was not using the right tool for the job.... three of the bolts came off fine with a T50 but the last one just ended up stripped (See that attached image).
I tried everything I could think of until I finally went out and bought a T55 socket, I tried to fit it into the bolt head with not much luck until I finally just took a heavy hammer and knocked the every living crap out of it.
Was finally able to get it to turn loose while slowly applying pressure to my breaker bar.
I really just wanted to post the picture so if any of ya'll are running into a stripped bolt just know it can probably still be salvaged before handing her over to a stealership.
Safe wrenching everybody!
greenerobnmu
Rob
Clarkston, MI
2019 JLUR
How do you like the reinforcement?
IndustrialAction
Patrick
Slower Lower Delaware
2019 Wrangler JLUR
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Tailgate hinge actually takes a T55, not T50, hammer in the bit to break the paint for a snug fit.
jfarrell
jfarrell
Joshua
Mesa, AZ
I like it, feels like a poor mans reinforcement though... but I just could not pull the trigger on the 600+ for the proper mopar kit.
Gets the tire off my bumper and relocates my third brake light so people can actually see it again.
D60
CO
JL
I've got the same thing, using it with the EAG relocation bracket from Amazon 'cause at the time I ordered it was much cheaper than the Redrock relocation bracket (no longer true last I looked).
I kinda think the Redrock stuff and EAG are the same manufacturer but don't have enough data to prove it.
Anyway I felt build quality of the Redrock reinforcement was quite good. Welds were nice, construction made sense.
I drilled and tapped it for my CB antenna bracket, too.
Immediately after install I dropped off a big ledge in Moab and caught my spare. It buckled the tg sheetmetal between the hinges a little but I'm convinced without the Redrock reinforcement stiffening things up a bit it would have been much worse.
Kinda funny, I was getting a "warble" from the sheetmetal damage until I came from the inside and knocked it out.
