Redline Tuning Hood Struts - 5 minute Bolt-In installation!
jurassic3k
Jason
Wisconsin
2021 Wrangler Willys, 2021 Kia Telluride SX AWD
@jurassic3k
What are the number markings on your struts.... This will tell what you installed/have...
I'll let Redline Tuning work this out with you.... perhaps it is a YOU issue..... 8-) and not that the struts are the wrong ones.... Can tell you though if it is a YOU issue you are the 1st.
To me your video shows no issue that I would be concerned about..... I see no bounce ....
If this is how everyone else's works then so be it...better than what was there before
Heimkehr
Pennsylvania
2021 JLU 2.0T
I installed mine yesterday....they seem to be a little too strong and forceful when opening. Not sure I like it. Kinda bounces the hood
From new, the Redline struts on my JLU raised the hood in a slower, almost lazy manner when compared to the struts on your Jeep.
I do wonder if you were sent the higher force gas springs that are intended for the heavier hoods on the Mojaves and Rubicon 392s. See the yellow highlighted text in the product description.
If you determine that yours are the regular-strength struts, then perhaps there are manufacturing variances that explain the difference in performance between mine and yours.
jurassic3k
Jason
Wisconsin
All I can compare it to is my Kia Telluride factory struts:
Heimkehr
Pennsylvania
2021 JLU 2.0T
Yep. That's how the Redlines raise the hood on my JLU. Nice and easy.
JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
I feel that my struts are a little more energetic than I was expecting but not to the point where it gives me concern. I am trying to attach a video of mine. If it attaches, its dark outside but can still get a gist of how the struts are opening the hood
JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
Worked on my end
Oh, ok....On my end when I look at the post I just see this......a play bar but No video feed.
Jeep Wrangler JL Redline Tuning Hood Struts - 5 minute Bolt-In installation! No Video
Well, if you all can see a video, then hopefully my struts are raising my hood at just the right speed and with the right amount of force, as Heimkehr says...."Nice and easy"
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Looks right to me. Didn’t struggle; didn’t launch the hood into low earth orbit.
SwissSteph
Steph
Switzerland
www.swissjeepjl.com
JL Wrangler Rubicon - Hella Yella - 2.2 Diesel
I had the opposite problem, ordered a kit for a "heavy" european hood and received the poor kit. My hood would not lift by itself and once fully opened would fall back down by itself.
The seller "Redline" intervened and sent me the right kit, after exchange everything is OK (I had put a message here above).
I just need to contact "Redline" and they will find a solution :like:
Redline Tuning
Redline Tuning
Rock Sponsor (Level 1)
Ann Arbor, MI
2019 Rubicon
Hello Jason,
The part number of the gas springs you have are correct for your application. After reviewing the video everything seems to be functioning correctly. The "bump" you are are hearing is where the gas spring is transitioning from the nitrogen gas to the oil inside the piston. This is what slows the gas spring down for the last inches of extension.
Regards,
Andreas
Multiple places..
All this Redline Tuning Hood Lift Strut talk, got me thinking........ I installed the Redline Tuning on my JL on 7/26/19 .... almost 39,000 miles ago.
I know I open and close the hood on my JL at the very least twice a day.... (I open hood when hot engine JL is parked in the garage) ............. that's a lot of flawless, no effort for me, ups and downs.
Today, the struts perform just as well as they did on install day in 2019..
Anyway, all this talk of the Reline Tuning offering go my hungry so to speak.... SOooo, in the mail, on the way to me ..... is a set of Carbon Fiber Sleeves for my Redline's.... They deserve it.... 8-)
https://www.redlinetuning.com/Carbon-Fiber-Sleeves-for-Redline-Tuning-Struts-s/2419.htm
Jeep Wrangler JL Redline Tuning Hood Struts - 5 minute Bolt-In installation! ccc.JPG
Chile1
Missouri
2018 JLUR & 2016 BMW X5M
Biotech Sales Management
i love the CF sleeves. What part did you order and are they once size fits all?
