aug0211
Thank you sir! As helpful as always. I knew you would be great with this one (a detailed, specific question)!@aug0211
Careful where you order hydro blue paint... The P/N PBJ Hydro Blue/Laser Blue may be the same, but that is no guarantee that it is the exact same color as your hydro!
In the past, Chrysler reused the paint code PBJ for hydro, which had already been used for a previous shade of blue (Atlantic Blue). How stupido was that... Anyway, not the same color.... they are two, distinct different colors. If you get old stock Chrysler PBJ it will not be the color you want.
You might want to have a back and forth with a company that does custom paint in touch up pens and spray cans. Let them know your concern and let them research and get you the color match you need. THEN, they are responsible to make it right so to speak..
For those reading this post.. and that want a/their paint code:
Color Codes:
- PX8 Black
- PAU Granite Crystal Metallic
- PDN Ceramic Gray/Sting-Gray
- PSC Billet Silver Metallic
- PBJ Hydro Blue/Laser Blue
- PQB Chief Blue C/C
- PRC Firecracker Red
- PY5 Nacho/Dozer
- PW7 Bright White
- PUA Gobi C/C
- PE4 Punk’n
- 1-C Clear Top Coat
- 2-P Primer/Filler
- PGE Mojito/Green with Envy
- PBM Ocean Blue Metallic C/C (2018-2020)
- PBM Steel Blue (2007-2008)
- PHG Xtreme Purple P/C
- PSQ Rhino C/C /Bruiser Gray C/C
- PYV Baja Yellow
- PJD Acid Yellow
- PLC Sunset Orange
- PGG Sarge Green C/C
- PTA Mojave Sand C/C
- PUS Blazing Saddle
- PTT Dune
- PKG Tank
- 1-P Corrosion Inhibitor
- PYC Amp’D
- PLB Copperhead P/C
- PDS Anvil
- PR4 Flame Red C/C
- PTW Rugged Brown
- PRP Deep Cherry Red P/C
- PBU True Blue P/C
- PFM Gecko Green
- PL4 Crush
- PGH Commando
- PS2 Bright Silver Metallic
- PBA Winter Chill
- PB4 Cosmos Blue
- PFD Sahara Tan
- PGZ Black Forest Green
- PYB Detonator Yellow
- PGN Natural Green P/C
- PVG Mango Tango
- PWL White Gold Metallic C/C
- PEM Red Rock Crystal P/C
- PQD Surf Blue
- PBS Deep Water Blue
- PAV Dark Charcoal P/C
- PW1 Stone White C/C
- PGJ Jeep Green Metallic
- PV6 Sunburst Orange
- PDA Light Graystone
- PJR Rescue Green
