Recommend Mileage for Brake Service?
thedoc29ca
Windsor, ON. Canada
2018 JLU Sahara
Service department is recommending brake service at 20,000kms / 12500 miles. Looking for confirmation on the best time for this service.
Thanks
At Risk Ute
Christian
milehightrails.com
‘94 YJ, ‘21 JLR, ‘22 JLUR XR, ‘23 392 XR
Retired Navy
That seems like an awfully short service interval. How much meat is left on your brake pads?
Joe C
Lees Summit, MO
2017 Rubicon JKU
that's probably just an inspection of the pads. pads and rotors should last 50k +. It's one of the things I look at every time I rotate the tires, about every 8k
thedoc29ca
Windsor, ON. Canada
2018 JLU Sahara
Service includes an inspection and lubrication of pins I'm told. I've elected to hold off until the 32,000km mark indicated into manual.
morricus
Illinois
2018 Rubicon Unlimited, 2015 GMC Yukon XL, 2006 BMW M3
I replaced my pads at 14000 miles, but only because I wanted to replace the OEM Ceramic with Semi-metallic. Both the rotor and the OEM pad had virtually no wear. The pins were just fine. Perhaps if you're offroad in mud often, I could see checking more often.
BrntWS6
Land of the FOID
2019 JLUS, 2002 WS6
Just replaced the pads and rotors on my DD after 100,000 miles. I can tell you that was too long...lol. Pads actually had some meat left on them, it was the rotors that were completely shot.
Pins are very easy to lubricate though if you are a DIY'r.
