Jeepsterfreak
TSB 07-002-18
Radiator Leak
Build dates 1/23-1/25 2018
Radiator Leak
Just posted up this TSB document and other TSBs in the first post.TSB 07-002-18
Radiator Leak
Thanks for the info. Just want to point out that my build date was on 01/18/2018 which I initially think I dodge the bullet. The mopar site doesn't show any recalls on my jeep either. When I was at the dealer this morning for an oil change, the tech told me my radiator need to be replaced which it was a surprised for me. So I double check the number on my radiator and sure enough it falls under the range of replacement. I would recommend everyone with January's build date to do a quick 3 minutes check.TSB 07-002-18
Radiator Leak
Hi Jay. Do you have the TSB # mentioned in this thread? https://www.jlwranglerforums.com/forum/threads/my-steering-issues-have-been-fixed.12843/Recalls
- Freedom Top Storage Bag
- (Recall U25) - May 10, 2018
- Cruise Control / PCM Unit
- (Recall U62) - May 25, 2018
- Steering Intermediate Shaft
- (Recall U48) - June 1, 2018
TSBs (Technical Service Bulletin)
- 2 Inch Mopar Lift Kit Front End Clicking Noise
- (TSB 02-006-18) - May 17, 2018
- Radiator Leak / Cooling Leak
- (TSB 07-002-18 REV. A) - May 24, 2018
- Update Uconnect Software Version to 1810.02
- (TSB 08-012-18 REV. C) - June 12, 2018
- Low Steering Assist at Highway Speeds
- (TSB 08-092-18) - July 7, 2018)
- UAS, UAQ, UCS and UCQ Radio Over The Air Software Version Updates
- (TSB 08-008-18 Rev. A (July 14, 2018)
- Fuel Tank Strap Not Fully Seated
- (TSB 14-004-18) - July 24, 2018
- [EMEA]: MIL Illumination, Reductant Pump 1 Control Performance (P208B)
- (TSB 18-046-18 Rev. A) - July 26, 2018
- [APAC]: Service Bulletin [APAC Only]: Rough Start in Cold Temperatures
- (TSB 18-058-18) - July 27, 2018
Issue Bulletins
- Transfer Case Not Completing Shift
- (Case # S1821000002) - February 14, 2018
- Sky One Touch Power Top Cable / Slide Guide Installation - Express Mode Calibration
- (Case # S1808000168) - June 20, 2018
- Exterior Door Handle Removal and Installation
- (Case # S1823000013) - March 9, 2018
- Backup Camera Inoperative / Blue Screen
- (Case # S1808000074) - March 16, 2018
- Mopar 2" Suspension Lift Kit Springs Bowed Appearance / Rubbing Noise
- (Case # S1802000002) - April 10, 2018
- Wind Noise from Lower A Pillar
- (Case # S1823999927) - May 11, 2018
- Squeak or Rattle Noise Between Sport Bar and Rear Interior Panel
- (Case # S1823000032) - May 22, 2018
- Parking Brake Lever Loose or Rattles
- (Case # S1805000007) - June 7, 2018
- Issue Bulletin: JL Soft Top Will Not Fold/Extend or Bows Bent
- (Case # S1823000036) - June 27, 2018
- Vehicle Won't Start / CEL Due To Lost Communication with Fuel Pump Control Module
- (Case # S1808000167) - July 18, 2018
- Switch Bank Aux Switches Don't Work or Work Intermittently
- (Case # S1808000182) - July 18, 2018
To check if your vehicle has certain recalls announced for it, you can check at the Mopar site: https://www.mopar.com/en-us/my-vehicle/recalls/search.html
This post is a wiki-post and can be edited by all members, so please feel free to add new recalls / TSB / service bulletins.
Any word on whether the rear passenger seat release clip breakage / tension cable routing will be given attention?Hello,
If either of you need any additional assistance while working with your dealers, we would be more than happy to help. Send our team a private message with additional details if you have not already.
Julie
Jeep Social Care Specialist
Repossessed ?? I hope not , sheeshNo recalls but My jeep got possesed this morning..
