There are likely other links but register your Jeep here and you'll always have info available. owners Manual, window sticker, recalls, etc.okay - good to know, and thanks - what's the link to check the vin for this recall (again) ?...
It should be noted that it probably will take a little while before it appears. If your vehicle doesn't show this recall now it could next week...There are likely other links but register your Jeep here and you'll always have info available. owners Manual, window sticker, recalls, etc.
Yep mine doesn't show any recalls yet. Guess I'm up to four things I can get done when I take my Wrangler in for this recall.It should be noted that it probably will take a little while before it appears. If your vehicle doesn't show this recall now it could next week...
MINE IS CLEAR TOO. NOTHING SO FAR. BUT THANKS FOR THE UPDATE. JOHNIt should be noted that it probably will take a little while before it appears. If your vehicle doesn't show this recall now it could next week...
Thanks for the update. I had a new 1999 Wrangler Sahara where the PCM failed at 1200 miles on my way home. Had to walk 2 miles to a phone to call for help (left cell at home). Took dealer 2 days to fine problem (it was intermittent). Would start afterRecall U87. Attached the whole PDF but below are the pages relevant to the JL.
