I had the same issue. Using my Google-Fu I went with Permatex Rear Window Defogger Repair Kit from Napa, which is an electrically conductive adhesive. No issues so far. I did spend a fair amount of time cleaning both surfaces before I stuck mine back on.It's a known issue. Covered under warranty if you still have one. Otherwise, there are a few threads about it here.
ThanksI had the same issue. Using my Google-Fu I went with Permatex Rear Window Defogger Repair Kit from Napa, which is an electrically conductive adhesive. No issues so far. I did spend a fair amount of time cleaning both surfaces before I stuck mine back on.
Are you going to order a new 2302-MSS Uni-Clip Defroster Tab ... / button.. Perhaps you can salvage the one on there now.Just ordered the Napa repair kit. Be here tomorrow FYI ( punkin’ nVulpine) from Napa, not going through the dealer b.s for this minor repair. Thanks for the info.
Not knowledgeable on that info so I’m going to try and use the one that’s on there. If not maybe you can update me on what to order. Thanks.Are you going to order a new 2302-MSS Uni-Clip Defroster Tab ... / button.. Perhaps you can salvage the one on there now.
