mergedown
- Jason
- Feb 11, 2018
- Columbus, OH
- 2018 JLU Sahara
I’ve had the dealership fix mine twice so far, and it just became detached again.
Same here. Scheduled to repair on the 10th. Annoying problem to have.I’ve had the dealership fix mine twice so far, and it just became detached again.
I had one of the tabs re-attached by the dealer back before the winter. I had been waiting for a frosty morning to try it out but have not had the rear window overly frosted to date this winter. But, the few times I have tried to use it it doesn't really seem to be doing anything at all. I have been dragging my feet but should really bring it back and have them check it.For those who got it fixed by dealers, did you check if it is working properly ? I got back mine recently and during a rainy day i figured out that the heating elements were not working. Going to bring it back to the dealer again.
When I got my Jeep (about a year ago) the cable was detached, so they replaced the whole rear glass. I did the zip tie and mine became detached today. Back to the dealer I go....What I noticed when mine popped of was that after I soldered the terminal tab back on and plugged the cable back onto it, the cable seemed stretched with the window open. It was almost straight between the small u-clip and where it plugs up to the glass. It relaxes as the window closes but it looks and feels tight with the window opened. So to prevent it happening again, I introduced slack in the open position and used a small zip tie to keep the slack between the u-clip and the plug. So far, it's held up. Maybe those of you that haven't had the tab pop off or has been repaired could try the zip tie thing to prevent it from happening
Mine held up through yesterday and now it's for someone else to worry about if it lets go. Unless Jeep brings back a modernized, yet true to the classic version of a Grand Wagoneer, I have reached the end of my Jeep trail.When I got my Jeep (about a year ago) the cable was detached, so they replaced the whole rear glass. I did the zip tie and mine became detached today. Back to the dealer I go....
Today is your lucky day. JEEP is hosting a roundtable today with JEEP engineers, executives, designers, developers.Well I just joined the club, noticed mine was detached on the passenger side and the solder job looks week..
Service Advisor said tech will determine if he can solder but said lots of times they have replaced the back glass, last few months of my warranty left on my 2018 so glad it’s covered, guessing the solder jobs are hit and miss on fixing this ?
Here's my best educated guess. There are 2 separate things going on here.But I guess my question is, why would the entire heating element be fried and why are so many of these going bad? Is it possible its not the windows and tabs at all but maybe the input? Did they perhaps run too much juice to these such that they burn themselves out, or "fry?" Does anybody know what wattage and amps these are supposed to be putting out? Maybe the electrical engineer wasn't talking to the window engineer who had designed for less juice? Is there an inline filter or fuse we can use to prevent reoccurrence?
I would ask them a lot besides why it failed like why did they bury the ESS battery along with a host of other thingsToday is your lucky day. JEEP is hosting a roundtable today with JEEP engineers, executives, designers, developers.
You can ask why the rear defroster fails.
Here is the link to the thread...
https://www.jlwranglerforums.com/fo...estream-roundtable.49622/page-15#post-1098235
Did you have to pop the glass bonding tab out of the connector and then snap it back on after using the epoxy on it.What I noticed when mine popped of was that after I soldered the terminal tab back on and plugged the cable back onto it, the cable seemed stretched with the window open. It was almost straight between the small u-clip and where it plugs up to the glass. It relaxes as the window closes but it looks and feels tight with the window opened. So to prevent it happening again, I introduced slack in the open position and used a small zip tie to keep the slack between the u-clip and the plug. So far, it's held up. Maybe those of you that haven't had the tab pop off or has been repaired could try the zip tie thing to prevent it from happening.
