Rear Trackbar necessary after lift? And if so, bracket also needed?
Chipe
Chip
CT
Silverado
I have everything for my front suspension now, so I'm starting to concentrate on what I might need for the rear. I have the Mopar lift. Should I put in a rear Trackbar? And if so, should I also put in a Trackbar relocation bracket?
Thanks!
sourdough
left coast
JL
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
Chipe
Chipe
Chip
CT
Silverado
Did you install an adjustable track bar as well? Or just the bracket?
My question as well! :)
Carlton
Chicago
Jeeps lots of jeeps
What did your alignment numbers say? Mine is great without a bracket or adjustable rear.
Roky
Roky
You just need the bracket or adj track bar but not both. You can do both if you want. I had rk adjustable track bar on with my Mopar lift, and when I switched to rk lift it came with the bracket so I installed it. I had to adjust my track bar all the way in to make it centered. But I didn’t mind, with 3.5 inch of lift I wanted to raise my track bar anyway . To get what little bit of better roll center it gives....:)
Chipe
Chipe
Chip
CT
Silverado
Which is better?
Roky
Roky
Which is better?
Either way is good, I personally like having the adjustability. With bracket it might be off center a little, but still be well within specs, or it could be perfect, but my ocd won’t let me settle if it’s off......Lol.
UKCATS
DFW
2020 JLUR Recon/2020 Mazda3 Hatchback
I play piano in a whorehouse
I added a rear adjustable bar. My OCD required it.
Chipe
Chipe
Chip
CT
Silverado
I hear ya'. Bar it is. :)
Chipe
Chipe
Chip
CT
Silverado
The bracket aligned the rear axle which was about 1/4 to 3/8” out. Why add an adjustable? I installed a HD adj. bar in the front because I installed a T.B. bracket brace that included the steering box sector shaft brace https://www.synergymfg.com/synergy-...-and-sector-shaft-brace.html?category_id=4897. Got it at discount from Northridge 4x4. Also, seen where someone heavily bent the factory frt. T.B. I have not heard of the rear being bent. If I do, I’ll get one then.
My choice was bracket or adjustable. I chose the bar because it wasn't all that much more $ and I believe it will give me more choice. I could be wrong since I'm so new to this, but I'd thought at least I'd give it the "old college try." so to speak.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Synergy, amongst other manufacturers and users, recommend both. The bar for fine adjustment and the bracket to lift the roll center to eliminate any "tail wag". Also, I'm pretty sure that Synergy uses a bracket on the axle side to lift the bar, rather than the frame side bracket that lowers the bar, like in the pic above. Maybe they can explain the difference between lifting the axle side vs lowering the frame side? @AllJumpStyle, if you please? I know I'm not the only one that loves learning more about these awesome machines.
Chipe
Chipe
Chip
CT
Silverado
I cannot find a Synergy rear bracket for a track bar for the JL, just the JK, so I went with the Teraflex.
Roky
Roky
If you decided to go with rear bracket instead of bar, rk relocation bracket is 100 percent bolt on, teraflex I think you have to do some drilling, not a big deal, at least that’s how it used to be. Might be different now. Just something to think about.
