Did you install an adjustable track bar as well? Or just the bracket?Just got back from test drive with this... https://www.quadratec.com/p/superlift/rear-track-bar-bracket-jeep-wrangler-jl-5824
rear relocating track bar bracket installed, totally worth it. moved rear axle 3/8” to center and more importantly got rid of the funny tail wag. BTW, I have the Mopar lift and I like it.
You just need the bracket or adj track bar but not both. You can do both if you want. I had rk adjustable track bar on with my Mopar lift, and when I switched to rk lift it came with the bracket so I installed it. I had to adjust my track bar all the way in to make it centered. But I didn’t mind, with 3.5 inch of lift I wanted to raise my track bar anyway . To get what little bit of better roll center it gives..../\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\
My question as well!![]()
Which is better?You just need the bracket or adj track bar but not both. You can do both if you want. I had rk adjustable track bar on with my Mopar lift, and when I switched to rk lift it came with the bracket so I installed it. I had to adjust my track bar all the way in to make it centered. But I didn’t mind, with 3.5 inch of lift I wanted to raise my track bar anyway . To get what little bit of better roll center it gives....![]()
Either way is good, I personally like having the adjustability. With bracket it might be off center a little, but still be well within specs, or it could be perfect, but my ocd won’t let me settle if it’s off......Lol.Which is better?
My choice was bracket or adjustable. I chose the bar because it wasn't all that much more $ and I believe it will give me more choice. I could be wrong since I'm so new to this, but I'd thought at least I'd give it the "old college try." so to speak.The bracket aligned the rear axle which was about 1/4 to 3/8” out. Why add an adjustable? I installed a HD adj. bar in the front because I installed a T.B. bracket brace that included the steering box sector shaft brace https://www.synergymfg.com/synergy-...-and-sector-shaft-brace.html?category_id=4897. Got it at discount from Northridge 4x4. Also, seen where someone heavily bent the factory frt. T.B. I have not heard of the rear being bent. If I do, I’ll get one then.
I cannot find a Synergy rear bracket for a track bar for the JL, just the JK, so I went with the Teraflex.Synergy, amongst other manufacturers and users, recommend both. The bar for fine adjustment and the bracket to lift the roll center to eliminate any "tail wag". Also, I'm pretty sure that Synergy uses a bracket on the axle side to lift the bar, rather than the frame side bracket that lowers the bar, like in the pic above. Maybe they can explain the difference between lifting the axle side vs lowering the frame side? @AllJumpStyle, if you please? I know I'm not the only one that loves learning more about these awesome machines.
If you decided to go with rear bracket instead of bar, rk relocation bracket is 100 percent bolt on, teraflex I think you have to do some drilling, not a big deal, at least that’s how it used to be. Might be different now. Just something to think about.I cannot find a Synergy rear bracket for a track bar for the JL, just the JK, so I went with the Teraflex.
