Rear steel bumper question
hoag4147
Colleyville, TX
2022 JLUR XR
Hey gang. Changing out rear Sport plastic bumper with steel bumper take off from Rubicon. The plastic bumper has studs from frame to bumper and steel bumper has studs built in and nuts are required?
Does anyone know the specs of the 4 nuts required? Hoping to pickup from local hardware store once know specs.
Just FYI - already changed flares to Rubi. Not that this matter but wanted folks to know so we donā€™t start replyā€™s about mismatch.
thanks all
hoag4147
hoag4147
Colleyville, TX
2022 JLUR XR
KO1159
Washington
2019 Jeep Wrangler JLU Sting Gray
Firefighter
I realized that after I posted it... I had to go to the dealer to buy a few bolts for my front bumper... much bigger hassle, but able to get exactly what I needed.
hoag4147
hoag4147
Colleyville, TX
2022 JLUR XR
Agree. Had to do same for front (skid plate brackets, pinch nuts, couple bolts, filler panel). Looks like may need couple pinch nuts and bolts for rear I didnā€™t realize from you PDF. Thanks
hoag4147
hoag4147
Colleyville, TX
2022 JLUR XR
In case anyone looking later. Never found exact part number however did confirm they are M10 - 1.50 threads.
DaltonGang
Houston, Tx
Can you elaborate on this statement?
From past posts, the problem people were having was that the rear bumper fit too closely to the tub(body). When the rear bumper cam in contact with anything, it rubbed or smacked the tub, damaging it.
i would go with an aftermarket rear, unless you could extend the rear bumper out a little more than factory.
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
Thanks
word302
Oregon
JLU
The real issue is the mounts are paper thin, allowing almost anything to push the bumper into the body. Both bumpers are way too light for the kind of wheeling I do.
AnnDee4444
ā€Ž
'18 JLR 2.0
I'm willing to bet the bracket flimsyness has something to do with the crash test rating
I wonder how good the bumper would be with stronger brackets. Maybe some aftermarket company could build something... It doesn't look like it's too complicated.
AnnDee4444
ā€Ž
'18 JLR 2.0
hoag4147
hoag4147
Colleyville, TX
2022 JLUR XR
mmai
Washington
2018 Jeep JLU Sahara
Did you need the parts circled in yellow? I have the tow package.
Jeep Wrangler JL Rear steel bumper question 1608088834324
Jeep Wrangler JL Rear steel bumper question C057BAB8-08C8-43AD-B654-E6A5B0AD035B
