Rear steel bumper question
hoag4147
Rick
Colleyville, TX
2018 JLU Sport S / 2022 JLUR XR ordered 2/18
Hey gang. Changing out rear Sport plastic bumper with steel bumper take off from Rubicon. The plastic bumper has studs from frame to bumper and steel bumper has studs built in and nuts are required?
Does anyone know the specs of the 4 nuts required? Hoping to pickup from local hardware store once know specs.
Just FYI - already changed flares to Rubi. Not that this matter but wanted folks to know so we don’t start reply’s about mismatch.
thanks all
hoag4147
hoag4147
Rick
Colleyville, TX
KO1159
Washington
2019 Jeep Wrangler JLU Sting Gray
Firefighter
I realized that after I posted it... I had to go to the dealer to buy a few bolts for my front bumper... much bigger hassle, but able to get exactly what I needed.
hoag4147
hoag4147
Rick
Colleyville, TX
Agree. Had to do same for front (skid plate brackets, pinch nuts, couple bolts, filler panel). Looks like may need couple pinch nuts and bolts for rear I didn’t realize from you PDF. Thanks
hoag4147
hoag4147
Rick
Colleyville, TX
In case anyone looking later. Never found exact part number however did confirm they are M10 - 1.50 threads.
DaltonGang
Houston, Tx
Can you elaborate on this statement?
From past posts, the problem people were having was that the rear bumper fit too closely to the tub(body). When the rear bumper cam in contact with anything, it rubbed or smacked the tub, damaging it.
i would go with an aftermarket rear, unless you could extend the rear bumper out a little more than factory.
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
Thanks
word302
Oregon
JLU
The real issue is the mounts are paper thin, allowing almost anything to push the bumper into the body. Both bumpers are way too light for the kind of wheeling I do.
AnnDee4444
Earth
Jeep
hoag4147
hoag4147
Rick
Colleyville, TX
mmai
Washington
2018 Jeep JLU Sahara
Did you need the parts circled in yellow? I have the tow package.
Bestop
