CarbonSteel
Anyone know what the part number is for it? It is the 90° fitting that goes into the rear of the valve cover that the PCV hose connects to.
Thanks!
Thanks!
Not the fitting itself, the o-ring or gasket that fits into the valve cover. The OEM tube has been removed as I am running a UPR catch can. I noticed the fitting is leaking at the valve cover junction.
Not the PCV (it is on the front of the engine, if my memory serves).By fitting, do you mean the PCV valve itself? Might as well replace the valve if you have to pull it off to reseal it.
68210345AC for the PCV valve with O-Ring
68217337AA for the O-Ring alone.
OK; I thought the PCV was on the front of the engine on the left side. The elbow is UPR and I have reached out to them to see about a replacement or if there are replaceable seals. I will go ahead and grab a new PCV as well--might as well change it and the oil control solenoid o-ring on that side as it is leaking some too.That’s the pcv valve. The leak is most likely from that elbow that it looks like UPR supplied.
If that elbow is the oem part, it’s not serviced separately from the hose.
How much of a mess did this leak make? I just noticed a leak and it looks to be coming from that location. Glad I saw this as now I have a place to start!@mwilk012 - I went to grab a photo and I can see it may actually be the UPR hose that is the issue (unless the valve cover nipple is cracked).
I'll ping them.
It has not started dripping yet, but there is a pretty heavy oil film around the PCV "nozzle" and around the top of the valve cover. What I cannot tell is if this is the PCV hose leaking (note it is the UPR hose going to the catch can) or if it is the actual PCV.How much of a mess did this leak make? I just noticed a leak and it looks to be coming from that location. Glad I saw this as now I have a place to start!
Part Number | Part Name | Price | Quantity | Total |
68210345AC | PCV - VALVE 68210345AA | $22.47 | 1 | $22.47 |
Thanks for the details.....Been cruising BITG as well, I see you've spent some time there as well!@snapper692 - did some searching and one of the guys on the BITOG forum posted this:
I literally had to break the tab off the old one as I could not release the tab and turn counterclockwise at the same time. Not to mention aligning the new one into the keyway turn lock by feel of hand.
This was my concern; e.g. not being able to manipulate the tab and rotate it WITHOUT damaging the valve cover. The end of the exhaust camshaft fits into the opening on the PCV (brown area) so I would surmise removing the valve cover would not help either.
I will be diving into it after the holidays and changing the o-ring on the variable valve lift solenoids as they are leaking too (both sides). The driver's side will be more than a PITA to change, but the passenger side is not too difficult:
