Ready to buy my first lift! Quick question.
BpBpImaJp
Luke
Washington
'18 JLUR, '16 Cherokee Lat
I am ready to buy my first lift on my first Wrangler. JLU Rubi. 2018.
MC 2.5". With new front drive shaft.
Do I buy it directly from MC?
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
Two options, buy directly thru MC or thru a local authorized installer. Their page is down for that but if you call them and ask Iā€™m sure they can give you that info. They donā€™t sell thru internet retailers.
Brett
BpBpImaJp
Luke
Washington
Brett
Good to know! Thanks.
rustyshakelford
Brett
Navasota, TX
Also do you think it's best to get the drive shaft through them as an add on option or but one myself elsewhere?
I use their drive shafts a bunch. They are 1310 joints but work great. I want to say they are between 5-600 shipped. Takes about an hour or less to install depending on how comfortable you are doing that. 32mm, 15mm and I believe a 12pt 8mm is really all thatā€™s needed
Brett
BpBpImaJp
Luke
Washington
Brett
I should be able to do that. I'm still learning but have some ok mechanical skills.
Thanks for the advice btw.
You might be able to give me an opinion on this:
So I'm trying to decide between the 2.5" MC game changer with 35s or the 3.5" MC Game changer with 37s on 2018 JLUR.
I'd like to drive this thing on long trips but it will not be my DD. (Wouldn't mind a trip from the Pacific Northwest to Moab once a year.). Is the 3.5/37 setup to much? 3.5/35 looks kinda silly and 2.5/35 seems kinda small. Especially with steel bumpers, winch, etc.
rustyshakelford
Brett
Navasota, TX
We love the 3.5ā€ and 37 combo. Performs great. With an auto a regear isnā€™t super critical and looks balanced
Brett
Alacon01
Cody
Fayetteville
www.instagram.com
what makes you say you need a new driveshaft on 2.5" You really won't need it until 3.5+
ExitLeft
Wes
Philly ā€˜burbs
2003 Jeep Wrangler TJ
From all my reading on the interwebs, my understanding is that it isn't so much the 2.5" of lift, but the amount of droop the MC shocks allow. The droop permits the OEM driveshaft to contact the fuel tank/skid.
rustyshakelford
Brett
Navasota, TX
Itā€™s a cross member in the front that has clearance issues. The rear is fine
Brett
Alacon01
Cody
Fayetteville
www.instagram.com
I forgot about the 6 packs, they will do that. I would go other directions, but if flex is what you want they will do that. I actually ran my stock front shaft with a 4.5" lift and wheeled it pretty hard, but I also knew it was a time bomb.
BpBpImaJp
Luke
Washington
Brett
So with the 3.5 Lift/37s What offset on the rims did you need to clear the suspension?
I saw on their site that the backspacing is <5.5 inches. Im new to this but I calculated backspacing as
(8.5 inch rim + 1 Inch)/2=4.75 Backspacing with 0 offset. So to stay below a 5.5 inch backspacing I would need 5.5-4.75=0.75inch=0.75*25.4=19mm offset or less?
So that would tell me a +10mm offset or less (ie -10mm) would give me <5.5 inches backspacing on an 8.5 inch rim.
Does that Sound Right?
rustyshakelford
Brett
Navasota, TX
Every Jeep weā€™ve built we choose the less than 5.5ā€ back spacing and all have been perfect. From 0 to -12 offset I believe on the rims. We cater to the crowd that wheels their rigs so I donā€™t have much experience with any wild or crazy offset rims though. Plenty of clearance on these 3
Red one is neg 12
White is 0 offset
Yellow is factory wheels with 1 5/8 synergy spacers
Brett
BpBpImaJp
Luke
Washington
Red one is neg 12
White is 0 offset
Brett
Awesome! Thanks. In the mean time MC got back to me also. They stated with a 4-4.5 inch backspace on a 8.5 inch wide rim the offset would be between -6 to -19 mm.
