Virginia RCV Ultimate Dana 44 JL/JT Rubicon Chromoly Front Axle Shafts--New
Gogged
VA
I bought these but never installed them, still New and in box, $1100 cash/paypal, these are $1300 new...
I will ship for extra. I decided I want to buy other stuff right now so not installing them. Located in Northern Virginia.
Manufacturer Info here and below pics: https://www.rcvperformance.com/ulti...set-for-jeep-wrangler-jl-rubicon-1-piece.html
The RCV Performance Ultimate CV Axles for Jeep JL & JT Rubicon Dana 44 provide unmatched strength and smoothness you can feel. The RCVs simply replace your OEM Jeep JL or JT axle shafts with a high-strength constant velocity design. Our CVs eliminate oscillation and "crow hop" caused by the uneven power delivery of a u-joint axle. The RCV CVs provide 6 points of fully-engaged contact throughout any angle up to 45 degrees, providing 100% strength even when the steering is turned to lock.
The RCV Performance Ultimate CV Axles for Jeep JL Rubicon Dana 44 provide unmatched strength and smoothness you can feel. The RCVs simply replace your OEM Jeep JL axle shafts with a high-strength constant velocity design. Our CVs eliminate oscillation and "crow hop" caused by the uneven power delivery of a u-joint axle. The RCV CVs provide 6 points of fully-engaged contact throughout any angle up to 45 degrees, providing 100% strength even when the steering is turned to lock.
The RCV Jeep JL CV for Dana 44 is 18% larger than our previous Dana 44 design and uses our same Dana 60 architecture. Tests prove our axles to be twice as strong as OEM. Even with big tires and big power there are no worries. RCV Performance Ultimate CV Axles are low maintenance and operate with a smoothness you can feel - whether off-road or on the street. All backed with a Lifetime Warranty against breakage up to a 43" tire.
RCV axles are a direct OEM replacement for Jeep JL Wrangler Rubicon and Jeep JT Gladiator Rubicon. CVJ44-JL eliminates the Jeep's "Front Axle Disconnect" coupler for a 1-pc shaft, but keeps full functionality of the FAD module. No warning lights, and no further modifications needed.
Kit fits all JL and JT Rubicon models with 2.0, 3.6, and diesel engine options.
Additional Information
RCV Dana 44s are stronger than OEM Dana 60 u-joint axles
We launched this new 18% larger CV specifically for the Jeep JL & JT Rubicon
Running RCVs gains more strength than a Dana 60 while allowing you to keep the same wheels, less weight, and more ground clearance
Axles outboards are gun-drilled with a grease fitting at the end for easy maintenance when needed. No need to remove any parts (but a center cap on the wheel)
We offer two versions - the FAD 2-pc version and a FAD eliminator 1-pc version. Both versions retain the FAD module. No warning lights, no issues.
Coupler utilizes upgraded aircraft grade materials
RCV FAD kits use a new bronze bushing, replacing the OEM plastic.
JL Rubicon Dana 44 axles backed by a limited Lifetime Warranty against breakage up to a 43" tire.
Axle set includes right and left CV axle shafts, outer stubs, SST seals and installation tool, installation instructions, synthetic moly grease, and installation hardware. Black oxide coating is standard. Optional nickel plating is available for extra corrosion resistance in salty environments - contact us for details
WillysJeepGladiator
William
Oklahoma City
2020 Jeep Gladiator Rubicon
Are these still for sale?
ALEX-4LO
Alex
No where
2018 JLUR & 2020 JLUR - Project JL's
let me cop those for cheap?
Tazer JL - Z Automotive
