CaJLMetalHead
I had the very same issue!... the links are way too long... and I have the Rough Country 2.5 inch lift kit.. the long links combined with the brackets causes the sway bar to be at a 20 degree angle...I ordered and received the Rancho disconnects. They look to be of solid build, but I had issues on the install that prevented me from completing the project. I followed the instructions and it seems pretty straight forward. I got the 2 relocation brackets on the axle mounted and went to install the links and realized they are way too long. I cannot shorten them enough to fit between the sway and axle. The relocation brackets actually raise the connect point which in turn shortens the link. The Rancho links at their shortest point are 3/4" longer than the OEM links. I don't see how that will work.
I've emailed tech support and hope to get a resolution soon. Of coarse it was a PITA because I had to take everything back apart and re-install factory parts. I was so looking forward to not have to wallow in the dirt to disconnect this weekend.
BTW, my local Jeep shop highly recommended the Rock Krawlers. I did like the Rancho solution for holding the links out of the way vs. a strap so i ordered the Rancho's instead. Maybe I should listen to the experts.
also the links do not seem to have the appropriate curved shape to align with the sway bar...
Compare them against the Rough Country links:
