- Matt
- Oct 16, 2016
- CA
- Website
- www.gorancho.com
- 2013 JKU
The Rancho Rock Gear off-road front and rear tube doors are designed to give you added visibility while off-roading. Made from 1.25-in steel tube construction, these off-road doors mount to your original equipment hinges, and use the original style latch that can be opened from the inside or outside. Door limit straps included to prevent Tube Doors from swinging too wide and damaging your vehicle. Included rubber bumpers insure the doors do not rattle at the latch. Hinge design allows for fine adjustments to door location. Designed for use with OEM style 2018-2007 Jeep Wrangler JK non-power, non-heated mirrors. . Finished in a durable black powdercoat finish, and all necessary hardware included.
This product is for slow speed, off-road use only. It is not intended as a safety restraint device. Always wear your seat belts and avoid sharp turns and other abrupt maneuvers. Please check state and local laws before installation.
Check with your favorite retailer on cost!!
