Rancho Performance Adjustable LCA's or Synergy?
Chipe
Chip
CT
Silverado
Reviews/recommendations wanted: I am going to buy a set of adjustable lower control arms and have narrowed it down to either Rancho or Synergy. Rancho is significantly less expensive yet the specs on both sets of arms is pretty much the same.
Any advice?
EDIT: I have the Mopar 2" lift kit installed at the dealer.
word302
Oregon
JLU
Any advice?
The specs on any adjustable LCAs are basically going to be the same. Avoid Rancho. Look at Metalcloak or Rock Krawler.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
Mechanic
Synergy is a solid company. Their arms are built quite well, and most importantly they are using a joint that is far better than most of the competitors. Of your two options, I would definitely go with the Synergy.
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
Synergy. I’ve run their arms and they are top notch. Metalcloak too. Depending on the wheels you run the Rock Krawler arms aren’t bent for clearance, if that makes a difference.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
Mechanic
I'm personally looking into Synergy over the Metalcloak because the Synergy arms are built heavier. I don't know of anyone damaging any Metalcloak arms, but better safe than sorry.
OnlyOne
I’m fan of both. You can’t really go wrong with either one. It’s up to the color now. Lol
Chipe
Chipe
Chip
CT
Silverado
Do you think I should also put on geometry correction brackets?
OnlyOne
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
Mechanic
After holding a LCA from Metalcloak in one hand, and a Rock Krawler in the other, I have rethought about getting the MC control arms. I still think that they have an amazing product, but I want to check out some other options.
word302
Oregon
JLU
No they're bent the right way, up for ground clearance.
word302
Oregon
JLU
Don't forget the Rock Krawler is guaranteed for life.
OnlyOne
As I said before. They are not bent for clearance if you’re not running the wheels they require. Has nothing to do with ground clearance. That’s a whole other matter.
SpookyXJ
Ed
TX
2019 Sport S 2 door auto
I considered both companies arms and went with Synergy. I have Synergy control arms and Rancho track bars. Both are high quality but I give the edge to Synergy for build and finish but the price is a bit high. I would have gone all Synergy but their front track bar is still in development. The dual durometer joints used in both are very similar.The main difference between the 2 companies control arms is the length adjustment mechanism. Bends for clearance also appear to be a bit different between the 2 sets.
Synergy arms can be adjusted for length while installed on the vehicle and use a pinch bolt to lock the arms down. It works just like the adjustor for the factory drag link. This makes it super easy to adjust for castor or to center the axle in the wheel well if changing spring height.
Ranchos arms use jam nuts to lock the arms length and the adjustment end needs to be removed from the vehicle to increase or decrease length.
FWIW on the Rancho front track bar locking the jam nut down while on the vehicle is a PITA as it is partially covered by the bracket but it can be done if you remove the steering stabilizer and get a crows foot wrench in there at an angle. No issues with the rear.
word302
Oregon
JLU
No, my point was the Rock Krawler arms are bent up for better ground clearance.
