Rancho 2-3.5 lift on 34s
DustinM3
Dustin
Nevada
18 JLU
Thought I’d share my lift install today with the Rancho 2-3.5 sport lift with 9000xl shocks. Running the nittos 285/75/17 and loving the look. Paired the lift with a RC adjustable front track bar. Rock Krawler rear track bar bracket .5 Tera flex spacers up front to correct rake and Rancho geometry correction brackets. Came out riding way better than stock and feel amazing. Very happy with this setup!!
Jeep Wrangler JL Rancho 2-3.5 lift on 34s 2B127485-6063-49A4-953E-B67CD9E8A94A
Jeep Wrangler JL Rancho 2-3.5 lift on 34s 50D398CB-5174-49A9-A18B-4EA6B95D79E1
Jeep Wrangler JL Rancho 2-3.5 lift on 34s 3465E27E-C60B-4287-AC8A-0F8D0579384A
NyRey87
Nyles
Reno, NV
2020 Jeep Wrangler Unlimited Sport
Looks great! Mine’s in the shop right now getting a Clayton Off-road 2.5” lift abs I have the same size tires. I was worried they might look small but they look perfect!
Mikester86
Michigan wishing I was on a trail...
2022 JLR
I had the Rancho 2” lift on a 2020 JLUR. I had Rancho’s front and rear track bars and their Geo correction brackets. Set the 9000 shocks to 4 and really liked the ride quality. Plus you get a little more suspension flex over stock.
It really is a solid choice for the money! Looks great, enjoy your Jeep!
DustinM3
Dustin
Nevada
18 JLU
I got close to 4 inches after install so hoping it settles a bit but even with that they don’t look too small
bwilson109
Byron
Katy, TX
I installed this same lift back in January, and while I like the ride quality, I'm getting a creaking sound whenever I first take off from a stop. I've re-torqued every bolt, but still can't get it to quit. Have you noticed any similar sounds on yours? Great looking Jeep, BTW.
DustinM3
Dustin
Nevada
18 JLU
I haven’t but from I’ve read it could be spring being seated properly. Check to make sure the little knub is going through the little hole on top of the spring bucket
bwilson109
Byron
Katy, TX
Thanks for the advice. I'll check that.
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
what you running now?
Mikester86
2022 JLR
you think you wanna do down the rabbit hole again of upgrades or keep it stock?
I added a winch, side steps and front Rokblokz mud flaps.
Don’t laugh, but it may stay stock. Drives great with the 2.0 Turbo and holds 8th gear all day long. Being a 2 door the break over angle is quite good as is.
The length of the JLUR begged for a lift and larger tires. Not so much on the JLR in my opinion. It is my daily driver and weekend warrior. If I see the real need for a lift after some off road adventures, I’ll contemplate it then. Maybe Clayton’s 1.5” lift and some 34ish” tires. Time will tell.
I’ll take a jab at myself here:
Jeep Wrangler JL Rancho 2-3.5 lift on 34s 765AD064-F674-448F-B000-2E087EBA469A
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
nothing wrong with that haha, still a jeep...I wanted to get into a big lift and tires but honestly I dont have time to make it a trail rig because of my work schedule. Still enjoying my sport though for beach and dunes in stock form.
