Rampage Tonneau Cover?
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
I cannot post pics now but have had the top down with the cover in place.
The top will not go down enough to lock in place but no issues. I have a bigger tire that sits high so it does not cut anymore visibility.
laroo
FL
2022 JLUR 4xe
Hi Laroo,
could you post pictures of the duster installed, top down?
thx for the help!
Patrick
Here it is with cover completely on. I strap both sides down to keep it from bouncing around since it doesn't lock.
Jeep Wrangler JL Rampage Tonneau Cover? IMG_20200513_112928
Here are some older pictures, first shows back part of cover unattached and stuffed in the tub, second pic shows the top completely down and locked. I run both ways, but mostly with the cover on and strapped because it's a little easier.
Jeep Wrangler JL Rampage Tonneau Cover? 20190914_073114
Jeep Wrangler JL Rampage Tonneau Cover? 20190914_073230
Pat’s Sahara Unlimited
Patrick
Mont-Saint-Hilaire, Canada
2019 Wrangler Sahara Unlimited
Thank you so much!!! I like the straps. No chance of damaging the top system, you think? I’ll never run with the top completely removed. Less manipulation = less risk of damage, therefore I’ll never hook up this tonneau to the tailgate bar. I guess I’ll go With the GPCA model, even if it does cover as good, since that 10 in. that people complain about will be taken by the folded roof. I’m not looking for weather protection, but to hide sutff from prying eyes while stopping somewhere for a short time.
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
It is a Jeep soft top. Very durable. Take care of it but you are not damaging it by using the cover as designed. The straps are fine - just do not bend or put any undue pressure on the tubes.
AZ Hella
Sonoran Desert
JLUR
FYI. CJ pony parts has the tonneau and wind deflector in stock. Great price too.
cojeepz
T
colorado
2018 JLU Sahara
cojeepz
T
colorado
2018 JLU Sahara
Laroo, what kind of soft top do you have?
tribefan
Lancaster, SC
2023 Willys XR
TBONE1997
Todd
Carmel, IN
2018 Jeep Wrangler Rubicon
Do you need a bar in the back to secure it? I have a hard top, just looking for something to keep people from looking inside when naked. I have a RainGear cover, so I don't care about it being rain proof. Thanks.
AZ Hella
Sonoran Desert
JLUR
Technically it you do need the bar but, you can probably get away without it.
AZ Hella
Sonoran Desert
JLUR
Thanks Billy Goat
The bar and end caps are probably not to expensive. There are posts earlier in this thread that say the JK bar works ( which would/should be cheap ). The end caps can’t be too much. I can tell you with the bar it’s a super tight fit.
there are many other tonneau options that don’t use the bar but, all the best ones do.
flyer92
Nevada
Any thoughts on which tonneau is better...Quadratec or Rampage?
