cbrenthus
If you think it still has moisture, go get some DampRid - that stuff is pretty awesome. I used to use it in my boat's cabin and it took away all the mustiness
If it happens to get wet again i got a new cluster from instrument cluster store, they had a bunch for like half the price that my dealership offered me.Thankfully very little water got on the dash and instrument cluster. I was able to blot that up no problem last night. Drive it a lot today to get air flowing through to help dry up everything. All the electronics still work perfectly. I think jus cuz very little got in there though. Otherwise I could see things getting screwed up and shorting out.
Mind sharing this info, just in caseIf it happens to get wet again i got a new cluster from instrument cluster store, they had a bunch for like half the price that my dealership offered me.
Last night it rained so bad and I forgot to put my Jeep in the garage. Top was down and I had an inch I mean an inch of water in the floor. I pulled the drain plugs and drained to the water. Got all the water out of the soft top. Used up every towel in the house to soak up everything in the carpet. Of course I dried instrument dash board cluster immediately. Overnight I put a fan in there to help it air dry too. I’m getting ready to take it to church so it’ll get some hot sun on it for drying too. Top down again of course to get more wind. Is there anything I need to do to help dry and prevent any further damage? Any advice is much appreciated. I know I’m stupid and now I’m worried it’s gonna smell like musty carpet when it’s all said and done. My wife was a sweet heart and helped me soak up the water. Probably did a better job than I did as all I did was panic and yell for 20 min. Unreal I’m so beside myself and upset.
It will be fine. I've been caught in torrential rain several times. This is a right-of-passage. To reiterate the advice from others on this chain, pull the carpet and vacuum the water out of it with a wet-vac, then let dry in the sun. Jeep makes these vehicles to absorb a lot worse than clean clear water. Think in terms of mud. Wipe the tub out.Last night it rained so bad and I forgot to put my Jeep in the garage. Top was down and I had an inch I mean an inch of water in the floor. I pulled the drain plugs and drained to the water. Got all the water out of the soft top. Used up every towel in the house to soak up everything in the carpet. Of course I dried instrument dash board cluster immediately. Overnight I put a fan in there to help it air dry too. I’m getting ready to take it to church so it’ll get some hot sun on it for drying too. Top down again of course to get more wind. Is there anything I need to do to help dry and prevent any further damage? Any advice is much appreciated. I know I’m stupid and now I’m worried it’s gonna smell like musty carpet when it’s all said and done. My wife was a sweet heart and helped me soak up the water. Probably did a better job than I did as all I did was panic and yell for 20 min. Unreal I’m so beside myself and upset.
I was going to ask who has pulled the carpet and used a bedliner. Seems like the only reason to have the carpet is to reduce noise and provide a little insulation. Then you end up putting all-weather rubber mats on top of that to protect the carpet. Why not just skip both and put some rubberized spray line in? Who has done this and has pics and a recommendation of which product to use?Sell the carpet once it is dry lol, use the money to line the tub...it will happen again, the choice is yours whether you want to pull the carpet again, or never deal with it again
Only issue you need to be careful of when doing the liner, I've heard of cheap installs that leave certain cracks and things exposed in the floor, between the tub and the liner. Then the water can get between the liner and the tub and cause corrosion and other problems. You want to make sure you have an experienced person do the install.I was going to ask who has pulled the carpet and used a bedliner. Seems like the only reason to have the carpet is to reduce noise and provide a little insulation. Then you end up putting all-weather rubber mats on top of that to protect the carpet. Why not just skip both and put some rubberized spray line in? Who has done this and has pics and a recommendation of which product to use?
Great tip!If you use a dehumidifier you will not have to pull the carpets, happened in my JK about a half dozen times. No weird smells. On top of that I think it dries out stuff you cannot get to. Like the inside of your dash.
Thanks for posting this. It was a good readStay calm. Your electronics should be fine. Read this: https://www.cnet.com/roadshow/news/jeep-wrangler-gladiator-tech/
