Radio volume soft even when cranked all the way up!
scottijohn63
Santa Barbara, ca
Toyota FJ Cruiser, Corvette Z06 Convertible
Sometimes this happens. Seems to clear up after four or fives starts. Anyone know what to do to clear it up when it happens?
Thanks!
DanW
Indiana
Thanks!
Yep, mine occasionally does that. That's one reason I love the Tazer. I can reboot it and it is cured.
Rhinebeck01
2018 2dr. Rubi
@scottijohn63
Well, if the quirk clears up on it's own after 4-5 starts it is undoubtedly UConnect related.. It is doubtful that your JL has a hardware issue.. sure it might, but doubtful.
When things get a muck with UConnect, what you usually see, is after 3 or 4 stop/starts of your JL, that the UConnect quirks go away..... go away til they return again.
You can hurry along the above scenario by doing an F97 fuse pull that causes UConnect to reboot and remedy a quirk... do this and you do not need to wait for 3, 4, 5 stop/starts for the remedy.
As for your low volume thing.... next time it happens, switch source to AM and then back to what you were listening to.. like XM. This switching to AM and back will more often then not, immediately remedy a no sound of low volume issue.. ... until the next time.. Fortunately, you are not going to see / be faced with your low volume quirk very often...
Yeah, you should not have to do the AM thing but..
DanW
Indiana
@scottijohn63
Thanks for the AM tip! That'll be quicker than the Tazer reboot and won't require a stop! I did get my Uconnect updated when it was in for the clutch recall and it has not happened since. Time will tell, but I hope it is cured.
Rhinebeck01
2018 2dr. Rubi
@DanW
No guarantees with the AM thing... it always works with no volume but not always... but does most of the with the low volume scenario. I rarely have the low volume or no volume quirl happen
Your Tazer JL Mini has the ability to reboot as you mentioned... but I could do an F97 fuse pull faster then a Tazer reboot.. I have pulled F97 so many times... I have it marked with white out for an easy find..
scottijohn63
scottijohn63
Santa Barbara, ca
@DanW
Thanks so much for your quick response. I will do the F97 fuse pull!
Rico1111
Rico
RI
2018 Rubicon 2 door JL
Just a heads up...if you do the fuse pull and have xmradio it will go away for about 10 minutes but it will return ....Happened to me and thought I screwed it up but it came back.
scottijohn63
scottijohn63
Santa Barbara, ca
Thanks for the heads up! Returned to normal this am with out fuse pull, but will use it in the future!
Tri-City Jeep
