Quick release bolts for hard top?
Ogre_FL
Cooks Bayou, FL
2018 JL 2 Door Sport S, 2021 Gladiator 80th
I am not sure about the T-handle ones, but I am not happy with the lessor expensive GP-Star LITE ones GPCA sells.
While technically it might be the correct size/pitch they are a very sloppy fit and come loose very easy. My top creaked all the time when using them and I had to tighten them often.
I swapped back to the regular bolts.
Jeep Wrangler JL Quick release bolts for hard top? GP-star-M8-thumb-screw-gpca-10-600x600
Albany
Albany
Long Island
Wrangler Willy's Sport 2 door manual
So it seems like the gpca ones are the way to go if doing by hand.
One question about them...is there a nut that I have to catch everytime I remove them? Or do they screw into the existing bolt hole only?
Chocolate Thunder
Jeremy
No nut, just a washer that helps spread the clamping force over a larger area.
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
Anyone using aftermarket bolt to hold on their hard top? Looking for a recommendation. Would like something that fits the thread of the JL holes. As in I don't want to worry about replacing the nut underneath. (JL is on order so I'm assuming it's same set up as jk)
I plan on using the top lift pro to take the hard top on and off a lot so looking for a simpler solution.
Thanks for any help.
Another vote for the GPCA T-Handles. I order them with my GPCA Pro cover. I remove the cover and still use them.
omnitonic
Southwest Virginia
2021 JLU Willys in Sarge Green
truck driver
I don't have time to dig up pictures, but I made some custom gib lock bolts for my shop machinery that would be perfect here. The top is a knurled knob that is cross-drilled and has a length of 1/4" drill rod fitted. You can spin them pretty fast, get them quite tight by hand, and they are essentially impossible to break by hand.
I may make a set of those sized for the Jeep. Sounds like an interesting shop project. I'd still have to use the torx bolt for the two at the front though, where the Freedom Panels overlap the rear top.
Hmmm.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
@Albany
Long ago I had some bolts with a T handle, that supposedly allowed for quick removal but they were more of a pain then anything.... slower to remove then me removing the stock bolts with a battery powered removal tool..
I use a battery powered tool now... use the stock bolts and D rings... With the battery powered tool the bolts with D rings come off fast fast...
Also, I wanted the much wanted D rings so I could use them with a net in the back.. or use the D rings to secure items..
https://www.jlwranglerforums.com/fo...-take-your-jeep-hard-top-off.3706/post-236224
https://www.amazon.com/gp/product/B076SCRTTJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.jlwranglerforums.com/fo...ou-do-to-your-jeep-jl-today.3033/post-1623266
This is the way
rockadile
PA
2019 Mojito! JLUR
I have the GPCA T-Handles and ended up switching back to the factory bolts since I got a cordless ratchet. The main reason for switching back is that they rubbed on my HotHead headliner.
Chocolate Thunder
Jeremy
How/where did they rub the liner? I have the same liner and don’t have any rubbing at all that I’m aware of. Now I will have to go check it when I get home.
rockadile
PA
2019 Mojito! JLUR
Honestly, I can't remember if it was the actual T head that rubbed on the HotHead side window liners or my hand when twisting the head. Either way, it is quicker to use the factory bolts and cordless ratchet (even factoring in the time to dig out the cordless ratchet ;)).
swflfireguy
naples,fl
2019 JLU Sahara
Retired Fireman
I'll chime in with my support for a battery-powered tool. Even a cheap harbor freight one will work wonders. I take my hard top off a lot in the early summer, since I can steal 2-3 days before it rains cat and dogs. Using a pair of ratchet straps and a battery-powered tool, I can remove the top quickly.
Albany
Albany
Long Island
Ok I'm a little embarrassed to ask this but...
If I got a tool to do the work what bit would I need? Is there a specific size (clearly I'm not very handy)
rockadile
PA
2019 Mojito! JLUR
The best tool for the job would be a cordless ratchet and a set of torx bits. There are many brands of cordless ratchets...from a cheap Husky brand one from Home Depot to higher end models like those made by Milwaukee.
The added bonus to having one is that it makes taking the doors off much easier, too.
Albany
Albany
Long Island
Thanks so much. I think this is way I will go.
