Question of the rpm for manual transmission
bio86250
bio86250
Leon
Chicago, IL
2020 JL Willys, 2022 JL Willys Sport
Drop the clutch every gear... it's good for it. It may not seem like it but you want it to grab hard every shift. Anything else is decreasing the life of the clutch. Also, shifting at 3500rpm is nothing for this motor, it loves to rev.
Note it, I'll give a try, thanks for sharing
Elsinore73
Long Island
2021 JL Wrangler Unlimited Rubicon
I think the JL has one of the best clutches I have ever driven, but the lack of low end torque on the 3.6 combined with the rubicon gearing means you want the revs up or it has a tendency to lug when short shifting. My previous car was an Audi A4 wagon with a 6 speed manual, that had tons of low end torque and loved to be short shifted, the JL not so much.
jdubya421
Jakob
Greensboro, NC
2020 Rubicon 2-Door MT V6
Curious why you say "combined with the rubicon gearing". The rubicon has a 4:10 gear ratio which is shorter than the other models meaning it catches better and has more torque multiplication. I have 4:88 gears and 37" tires and its slightly shorter than 4:10 and 33"s, but I can definitely short shift my Jeep. If you have the right gears for your tire size it will be fine at 1.5k rpm and shouldn't really lug or anything, maybe it will ping a bit.
zakaron
Pittsburgh, PA
2021 Willys 4dr, 2004 Pontiac GTO, 1986 Honda Nighthawk S
I do hope Rodeoflyer was joking about suggesting to drop the clutch in every gear. I would not recommend driving like this regularly. Sure when I'm on the drag strip with my GTO I'll drop the clutch between gear changes and smash the throttle back down to the floor, but that does create a shock in the driveline. The purpose of the clutch, besides disconnecting the engine from the drivetrain, is to ensure a smooth transition between engine speed and road speed. Dropping the clutch puts a shock load on the drivetrain components that can eventually cause them to wear and have excess play. You'll end up with a lot of clunking and slack takeup as this can affect driveshaft pinion / yoke joints, u-joints, diff gears, etc. I'd rather replace a clutch and pressure plate (which are wear items anyway) then troubleshoot a sloppy drivetrain.
jdubya421
Jakob
Greensboro, NC
Precisely. That's why it's a clutch pedal with travel and not an on-off switch.
Elsinore73
Long Island
Your right on the rubicon gearing being better for low end. I have never driven a non-rubicon manual JL so have nothing to go against as far as another JL goes. It’s all relative and coming from a turbo Audi I’m just not used to it. Anything sub 2k rpm’s has no guts and if my up shift leaves me sub 1700 it wants to lug. Running 315’s with the stock 4:10 gears. Love it though, not complaining, just my observation. The 4.0 in my old TJ was much better down low.
McCloude
Maryland
2021 JTRD / 2019 WK2 TH
Wait until you start learning the feel of shifting in 4 low. I'm still getting use to that..
But for me, 1->2->3->4 is 1k difference. 4->5 is 500, and 5->6 is 250 rpm difference. I generally shift at or above 3k rpm for the first 4 gears, and gauge from there.
beachbumm78
Kristy
Phoenix, AZ
2020 bikini blue Rubicon
Athletic trainer & Massage therapist
So true! Completely different shifting in 4L, 4H, and 2. All different.
McCloude
Maryland
I feel like a complete novice for the first hour, mostly for downshifting. But you do get use to it. You'll love crawling down a hill in 1st or 2nd. Starting after a stall on a hill is super nice in 4 low.
beachbumm78
Kristy
Phoenix, AZ
Yep same! Haha. It’s sooo easy in 4 low to just crawl down. Basically set it and go.
Maverick909
Inland Empire
www.instagram.com
3200-3500 before going to second. atleast with the crappy 3.45 sport gears. im hoping that the 4.10s will be much better. also note that the wranglers rpm are slower to drop than a normal older manual trans vehicle. its in the system to hold the rpms up a few mil seconds to " help shifts to be smoother. but its really just a PIA
entropy
Foothills of the San Gabriels
Jeep Wrangler Sport S JL 2-D
Professional dancer/male stripper
Just drive the jeep and do what feels good. If the jeep shakes, you shifted too soon. Let go the clutch by feel, learn the sweet spot at different speeds. It should feel natural. If it yanks, you did it too fast. Drive it smooth. Dont shift without the clutch, people think it is cool. It isnt. Wear down the clutch, not the gears.
McCloude
Maryland
And enjoy the stop start yelling at you at red lights where you go to shift too fast. I get beeped at often..
emptyminded42
Cleveland, OH
Hellayella JLU Sport S 6MT, Forester XT
Engineer
Yeah, you need to rev up the Sport to around like 3k when shifting otherwise you will probably end up getting bogged down.
The rev hang is an emissions control "feature" and is annoying but you just have to be patient.
mgroeger
Hurricane, UT
2021 JLUR 2.0T, 1991 YJ rock crawler
Some other things to consider, IMO.
Turn OFF the ESS.
Turn OFF the hill assist.
IMO this leads to a more "normal" feeling clutch. This engine loves to rev and I've rev limited it a couple of times when my music is too loud and I'm not paying attention... lol.
For 1st - 4th I will almost always take it up over 3k rpms before I shift. The 3.6L does not come alive until you are above 3k.
For what it's worth I'm running 37s and 4.88 gears.
