question: how to get wires to top of dash
Crawldad
Hagerstown, MD
'21 2dr wrangler rubicon, '18 Ram3500
i have a couple - three projects going
i want to get wires up to the top of the dash:
1. cb antenna cable (i will need a 1 cm "hole" to get the cable through)
2. power / ground for the cb
3. iphone charging cable
4. a +/- cable going to a 5w solar panel i can use to trickle charge my battery
(i probably won't be using the suction cups lol)
https://www.batterytender.com/Battery-Tender12V-5W-Solar-Battery-Charger-with-Windshield-Mount
oh ok 4 projects lol. anyways, what is the best way to get wires up top. near the center.
my mount will sit in the middle, after pulling out the rubber pad; i can pretty much mount anything to this:
there are two pre-existing screws which the grid will mount to. there are also 3 square holes (smaller than 1 cm) under the rubber pad... i guess i could hog one one of those holes out. unless someone has better advice on getting wires through the dash.
Captain Skip
Skip
New Hampshire
2020 Wrangler JL Sport S
Happily retired
I took my dash apart to make sure I could do it. (very easy job) https://www.jlwranglerforums.com/fo...the-best-of-me-time-to-hide-some-wires.60207/
I mounted my Bulletproof phone mount to the dash after drilling a hole in the base and adding a rubber grommet then drilled a matching hole in the dash. I ran a wire down from the top and taped the end of the phone cable to it which I ran up from the driver's footwell and snaked it through to the hole. All you need to take the dash apart is a couple small sockets - I think like 7mm if I recall - don't hold me to it, and a trim removal tool. Everything snaps out and snaps back in. I removed the radio before drilling the hole in the dash to make sure I had clearance for everything.
Punknhed
Virginia
2019 Wrangler unlimited sport
can you post a pic of the front of the dash where you have the chord plugged in, im curious to see where you ran the chord up thru at ? i have mine apart while im painting it, and have a new 67 designs mount to install as well. id like to do it all at once. thanks
Horsemover
Jamie
NW PA
2021 JLURD / 1997 TJ 4.0
Are you guys happy with the Bullet Point stuff? Looks pretty solid. I have been waiting for the 67D to come back in stock but might have to order up tonight with BP.
Crawldad
Hagerstown, MD
  • Thread starter
  • Thread Starter
  • #5
i just got the base. it's like $25
it's solid and it fits
Hogzilla
Bill
SC
2021 JLUR
I'm running the Bullet Point platform mount and it works great. I prefer the platform mount over the 67D rail.
Captain Skip
Skip
New Hampshire
Happily retired
. I didn’t take any photos of the dash off, sorry. I ran the wire to a double USB port that I installed under the steering column/dash. I plug my iPhone and dash cam into it. I don’t have any cables visible in front of my dash.
TopLift Pros
