Quake RGB Halo effects using two controllers
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
I'm doing some experimenting with the Quake RGB halo effects using two controllers. For this first attempt I was trying for some red, white and blue to start with, but there wasn't much to choose from. Then switched to some clock wise/ counter clockwise rotation and finally top to bottom/ bottom to top. The lights definitely look better in person than they do on the video.
Jondrew
Bob
Central Fl
2018 Rubicon
Not sure what you’re doing here. Do you have the headlights hooked up to one controller and the fogs to another or do you have left side on one and right on another? What app are you using?
I have two controllers, but I thought I needed splitters to run all 4 lights from one controller. I dont have the fogs hooked up yet.
Jebiruph
Jebiruph
Jerry
Iowa
I was split left side right side and using the app provided by Quake. If I remember correctly, by default the app will detect and control both controllers as one. Controlling them individually takes some extra steps. What I found running separate controllers was that I could never adjust the speed of the effects so that both sides stayed in sync, they would eventually drift apart.
Jondrew
Bob
Central Fl
2018 Rubicon
Neat. I just got my splitter today. Not sure if the wires are long enough. Might have to do some wire lenthinging. Rob from Quake said they are going to release their own branded app. Hopefully its better than the one out there.
Jebiruph
Jebiruph
Jerry
Iowa
Here's a write up on how to manage multiple controllers.
Access the device menu by pressing button at the upper left.
Jeep Wrangler JL Quake RGB Halo effects using two controllers dev menu button 2
This brings up the group devices page that shows the detected devices and any user defined groups. If you tap the top of the menu, it will re-scan fro devices.
Jeep Wrangler JL Quake RGB Halo effects using two controllers dev menu 2
Click on ADD NEW GROUP to add a group and enter a name.
Jeep Wrangler JL Quake RGB Halo effects using two controllers group naming 2
The new group will be added to the menu, tap on the new group to add devices.
Jeep Wrangler JL Quake RGB Halo effects using two controllers select add a device 2
Select the device(s) to add to the group.
Jeep Wrangler JL Quake RGB Halo effects using two controllers adding devices 2
Here's the group with the device added.
Jeep Wrangler JL Quake RGB Halo effects using two controllers group added 2
Once the groups are setup, you select a group to change it's current effect. Once an effect is set, it will stay in effect until it is changed through the app.
Jeep Wrangler JL Quake RGB Halo effects using two controllers gropu selected 2
Tap and hold on a group to delete it.
Jeep Wrangler JL Quake RGB Halo effects using two controllers delete group 2
