Quake LED Switch System QUIC798 Lighting/ 12v Accessory Controller...The Ultimate Headache Saver!
Quake LED
Summit Sponsor (Level 3)
Mr. Black
Denver
quakeled.com
JK, JL
Sweat Shop Manger, Slum Lord and Break Dancer
Hate running wires through the firewall, buying fuses and relays, or drilling holes in your dash? Stop spending money on expensive wire harness that are a pain to install and get your hands on one of Quake LED’s new lighting controllers while supplies lasts! This patent pending universal controller is the ultimate installation headache saver because it eliminates the need to run any wires through the firewall of your vehicle! Just connect the controller to your battery and then tie your lights or other accessories straight to the module and operate them with a remote control. Not only will it eliminate the need to pass wires through the firewall but the remote control will allow you to turn on and off your accessories while remaining outside of the vehicle providing extra functionality. The controller is rated for 60amps and should be the perfect accessory switch solution to most builds. It retails at only $99.98 making it one of the most affordable switch systems in the market and is the go to solution for anyone adding even just a couple of accessories to their vehicle.
Get yours from Quadratec, Northridge 4x4, Meyer, Keystone
Or Buy here: https://www.quakeled.com/product/universal-60a-8-led-light-controller to get your hands on one today!
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Nice !!! How does it hold up to heat and water?
Thanks! Heat is not a problem at all! We have sold tons of units since they came out and everyone runs them in the engine bay without issues. As far as waterproofing it does have open terminals on the side so we don't consider it submersible, but we don't have issues and live in Colorado with lots of snow. It would only become an issue if it was on and fully underwater, but if you are fully submersing your engine and battery I think we have bigger issues lol!
You could also run it inside the vehicle if you're jeep is Aquaman ha!
hellayellow
JOSE
DOWNEY, CA
2018 Jeep JL Wrangler Sport
TECHNICIAN
can you hook up on board air compressors and a winch to it ?
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
I would not use it for a wench unless you were using a massive relay to the battery and using our control box to signal the relay. Wench's can pull upward of 300amps under load so the box could not hand that amount of draw. The terminals on the side of our unit wouldn't except the 4 gauge wire most wenches come with. The compressor will not be an issue at all. ARB's on board twin high performance air compressor has a max draw of 50amps underload (28amps normal draw) and that is one of the larger ones I know of. Hopefully this help!
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
right on time! i really wanted for my lights only !
let me go get one
Maverick909
dang it. i would have picked this up two months ago before i found the amazon special thing. might get one anyways for my mums jeep. Looks like you got yourself a good product.
hellayellow
JOSE
DOWNEY, CA
TECHNICIAN
thank you
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
This looks great!!! I was wondering, if something happens to the remote, like you lose it or it breaks, can it be replaced?
Hey Mike,
In the case that your remote broke or got lost, reach out to us and we will help you purchase a new one. The good thing is, the remotes come with a visor hook and are compact enough to fit nicely in your pocket without causing discomfort so we recommend keeping it close lol hope this helps!
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
let me go get one
Awesome!! were you able to grab one? if not let me know, I would be more than happy to help!:like:
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Thank you! We were really excited to release the product as we knew it would be a big help and headache saver! If you're looking to grab one and need any help, let me know, I would love to assist you in any way I can!:like:
ebelp
Upstate NY
JLU Rubicon (bright white)
@Quake LED How does the remote send its signal to the control box? RF? I assume not IR or BT...?
Bri01
Connecticut
Jeep JLU MOAB, BMW X5 MSport
This looks great! I wanted to hook up some lighting but was not looking forward to the wiring process, which as you know is a headache. This definitely seems to simplify things. I just ordered one on your site!
supamyk
Long Island
2021 Rubicon 4xE
Hey Mike,
Sounds great! Thanks. BTW...are these constant power?
Winjet
